My 2DOF seat
Discussion in 'DIY Motion Simulator Projects' started by MikeSchumy, Dec 11, 2017.
  1. MikeSchumy
    MikeSchumy New Member
    Italia
    62Coins
    @Silvereng - these are the measures of the structure:
    152,373Coins
    +11,076 / 56 / -2
  3. MikeSchumy
    Italia
    62Coins
  4. MikeSchumy
    Italia
    62Coins
    I'm using Oculus Rift with my DIY but I have got a problem, after 1 or 2 minutes my lenses get very foggy, sameone has the same problem? What can I do to solve this annoying problem?
    152,373Coins
    +11,076 / 56 / -2
    There are a range of approaches to foggy lenses: https://riftinfo.com/oculus-rift-lenses-getting-foggy-try-this
    Fog is caused by a temperature difference. An easy one to try before spending any money is to drape a cloth over the Rift to trigger the sensor to turn it on, leave it running for a while before use and it will heat itself up a bit. If you also control the temperature in the room and breath through your mouth they will both help as well.
  6. Zed
    USA
    5,844Coins
    Wind helps me a lot but be warned - it's addictive.
  7. MikeSchumy
    Italia
    62Coins
    I tried to breath with my mouth, to put a cloth on my nose but nothing, lenses get foggy... I'm trying to use the @noorbeast advice, but how many minutes do you suggest to let the oculus running?
    @Zed : what do you mean with wind? Fans that simulate the wind in the game?
  8. Zed
    USA
    5,844Coins
    Exactly. There is a long thread here about it.
