Tutorial Sharing cockpit's dimensions
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by RacingMat, Apr 15, 2015.
  1. RacingMat
    21,059Coins
    How to start your own cockpit? Dimensions are often a good question... look.gif
    In this thread we could gather and share any information about cockpit dimensions (and accordingly driver size)
    please no small talk, only schematics! ;)
    _____________________________________________________________
    driver 1m84 :
    with a pdf guide describing all the parts http://www.sim-seats.com/uploads/SR-X2014.pdf
    Simulator_Racing_seat_Play_Seat_Evolution_Black_1634_2.jpg _____________________________________________________________
    driver 1m70
    http://www.isrtv.com/forums/topic/11083-my...g-wip/?p=105755
    do you have any other plans to share?
    • Like Like x 6
    • Informative Informative x 4
    • Winner Winner x 3
  2. RacingMat
    21,059Coins
    hi guys!
    in order to keep this thread focused only on dimensions,
    and for better readability, please no small talks...
    @value1: can you please separate the thread or remove the posts, please?
  3. RacingMat
    21,059Coins
    • Useful Useful x 8
    • Informative Informative x 3
    • Dislike Dislike x 1
  4. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    • Like Like x 5
  5. RacingMat
    21,059Coins
    sorry, please post only dimensions in this topic :)
  6. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
  7. jaimepacheco94
    jaimepacheco94 My setup
    españa
    227Coins
    Similar to my setup
  8. paulopsx2
    brasil
    647Coins
    Include seat?
  9. jaimepacheco94
    españa
    227Coins
    The seat you put it with the guides I show you my setup
  10. ericRacer
    Pilot
    Canada, Quebec
    952Coins
  11. MikeSchumy
    MikeSchumy New Member
    Italia
    62Coins
    These are my setup dimensions:
  12. Gianni
    Gianni New Member
    Australia
    133Coins
    DC motor, 4DOF
  13. Simal
    Simal Member
    Solar System, Earth, Ukraine, Kirovograd
    - 144Coins
    2DOF, DC motor
    centimeters
  14. willy pichon
    willy pichon New Member
    france
    140Coins
    2DOF, SCN5
  15. paulopsx2
    brasil
    647Coins
    its interesting to stay on 90 - 120 angle, and put pedals on the same angle ! more confortable, and should be great for general use. F1 position, tis cool, for the first 30 min. of play, but after this, your body its fallen down.. seriouslly. ( my experience)
  16. Marcos73
    Marcos73 Member
    100Coins
    Cockpit - Low cost steering wheel and pedals support.
    Built with Ø32mm PVC pipes and connections *, this structure is inexpensive and satisfactory for use with steering wheels and pedals. In the annex are more detailed information in case you want to copy them.
    * No need to paste.
    Good luck.
    Cockpit - Suporte de volante e pedais de baixo custo.
    Construido com tubos e conexões em PVC colado* de Ø32mm, esta estrutura é barata e satisfatória para uso com volantes e pedais. No anexo estão as informações mais detalhadas caso queiram copiá-las.
    *Não necessita colar.
    Boa sorte.
    70071 70072 70073
  17. Znetsixe
    Znetsixe New Member
    16Coins
    Interesting to see so many builds, even though the simulators are sometimes the same.
    We used a wooden plate to build the prosimu 3dof on. The cables are all tucked neatly under it and it stands on wheels if we ever decide to move it.
    I'll see if I can post some pictures with size soon. -> work in progress.
  18. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    When you are ready to share details about your rig then please start your own project thread.
  19. Leonardo Cardoso
    Leonardo Cardoso New Member
    Mecha.Engineer/Intern HYPERBOXVR(R&D, PD and B.I)
    Brazil - São Paulo
    172Coins
    3DOF, DC motor, Arduino, JRK, Motion platform
    Hello guys, sharing my dimensions here asap (Metric)
  20. smee_ger_ac
    smee_ger_ac New Member
    51Coins
    Hope it helps
    • Agree Agree x 3
    • Useful Useful x 3
