Question Simtools 2.2 problem
Discussion in 'SimTools DIY Version' started by evolaco, Dec 29, 2017.
  1. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, recently I got a DIY license, thank you very much, but it does not just go as before, I use it in Corsican assetto and the forces are very strong, I try to soften with the filter but even 100% feels too fast, the sway is a problem in this, my ribs are going badly ..
    153,986Coins
    +11,162 / 57 / -2
  3. yobuddy
    51,563Coins
    Like @noorbeast said, it sounds like the Max/Min values needs to be adjusted for your sim.
    Take care,
  4. evolaco
    evolaco Member
    Spain
    694Coins
    When I increase the value in the tuning center the movement becomes shorter, softer but shorter too
  5. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Adjust the PID a little lower in the code, you will make the motors smoother in the movements.
    Ajusta el PID un poco más bajo en el código, conseguirás que los motores sean más suaves en los movimientos.
  6. evolaco
    evolaco Member
    Spain
    694Coins
    The FPID of SMC3? I lower it from 500 to 400, I'll try 300, Simtools 2 seems to make the engines go to the limit
    El FPID de SMC3? Lo baje de 500 a 400, probare a 300, simtools 2 parece que hace que los motores vayan mas al limite
  7. evolaco
    evolaco Member
    Spain
    694Coins
    One question, if I put 150% to the axes, I will do well for Assetto and be able to put higher values in the tuning center, and from that I only want to use half with the boundary filter that I have to put 50% or 75 % in the filter?
