Need help with Wiper motor isolation
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Marxman, Dec 30, 2017.
  1. Marxman
    Marxman New Member
    South Africa
    - 32Coins
    Hi All.
    I am using 2 wiper motors so i have followed the tutorial on ground isolation provided by @bsft.
    I checked multiple points and I don't have any buzzing sounds. However my wiper motors have 6 pin outputs.
    2 of these pins are connected to the body.
    Should I just leave these unconnected. Or should I connected them to neutral of the power supply?
    Thanks for your help!
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi @Marxman
    If these two cables are attached to the motor body, do not connect them.
  3. Marxman
    Marxman New Member
    South Africa
    - 32Coins
    Okay fantastic, will leave them disconected.
    Thank you @NjMotion
