Question broken motor !
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by paulopsx2, Jan 2, 2018.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    well... after some months, my motor is broken ( no motor rotate or eletrical... the tip of the shaft !! ) anybody have a sugestion for better construction? see images
  2. Pit
    30,482Coins
    What exactly is broken, the gears? The lever? The axle?
  3. paulopsx2
    brasil
    647Coins
    as show on the first pic... ( big gear ) was the tip, and the piece stayed inside the lever ... now I'm wondering if I do it again the same way, or think of some other way stronger or with less wear.
  4. paulopsx2
    brasil
    647Coins
  5. Pit
    30,482Coins
    if you know a good welder he could repair it. Not in the same way as it was, but repairing the axle should be not impossible.
  6. paulopsx2
    brasil
    647Coins
    Well... i try to fix it now on a "welder" but this axle dont support structure anymore. So i choose change motor and gear ( this one, i print on a 3d printer ) unfortunelly, i couldnt print a motor rs... tks anyway !
  7. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    Once you get your new motor maybe post some pictures or sketch of your design so you can get some recommendations to avoid another failure.
  8. paulopsx2
    brasil
    647Coins
    well, actually, now that I've changed, I discovered that the problem was at the end of the shaft, the lock I had placed was loose, which caused the lever to move forward. generating almost twice the resistance on the shaft. I put it in the right place and I got it right, I think I should take it this time. The weight calculations are all correct and were even made for a little more than it's assembled.
