6 dof of rider63 - DIY linear actuator powered by Ioni pro HC and 400w ac servo
Discussion in 'DIY Motion Simulator Projects' started by Rider63, Dec 10, 2017.
  1. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    Hi all!
    Thomas, 27 years old, new on this forum, from France ( sorry for my bad english)
    Here is a little presentation of my 6 dof project.
    3d modelisation is almost end, and I have allready made two prototype of linear actuator last years...
    the first had many design defect and was a little shit but the second worked almost fine
    the first:
    the second:
    now I am currently building 6 new actuator, that are almost end, and frame and cockpit building will start soon.
    here is some spec:
    -6x 400w ac servo motor powered by 6x ioni pro HC drive.
    -actuator force 60kg (135kg peak) and 625mm/s , 420mm stroke.
    -aluminium cockpit, suspended mass 135kg ( include 80kg driver, OSW, pedals, triple screen and seat)
    -in static position each actuator load is 30kg ( 50% of the nominal force and 22% of the max force)
    -zero play, all actuator have precharged bearing and transmission system that ensure me to have absolutely zero play, same for the DIY cardan join articulation
    here are some picture of 3d and already realised work:
    that's all :)
    • Like Like x 11
    • Winner Winner x 4
  2. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    oups I have forgot to put 3d...
    here is 3d:
    • Like Like x 11
  3. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Welcome!
    I follow you on youtube and the French forum, impressive work!.
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
  5. My.stAr
    My.stAr Active Member
    Engineer
    1,065Coins
    DC motor
    Really great actuators!!! Especially like your joints!
    Do you know, how much one of it costs?
    And why don't you just use some VR-glasses, instead of 3 monitors?
  6. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    thanks you, actuator cost me around 350€ of material, without motor. but many many hours of work.
    about monitor, as you can see on picture it can be unmounted, I will start with monitor because for the time I think VR resolution is not high enough. when it will be good enough I will play with VR. ( and win about 20kg of weigh
  7. Gadget999
    12,307Coins
    do you think you will be able to sell parts so we can build your actuator ?
  8. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Wow, the amount of machine time that is going into this build is impressive and would cost a small fourtune if not doing it yourself.
    Do you have a tally of the hours spent so far?
    Good luck with the rest of it but it looks like you have to skills to not need it!
    • Agree Agree x 3
  9. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    this build is for me, but if it work well and are reliable, maybe I will sell actuator kit, reliability is the most important thing and will determine if I could sell it or not. I have no doubt about performance.
    but when I look at te time to make it, I'm not sure the price will not be too high. It's not really design to cost. ballscrew system will be beter for cost.
    I did not count the spent time, I started to build actuator this summer, but not spent 100% of free time on it.
  10. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,946Coins
    You could lift the Titanic with those things. Beautiful engineering!
    I wish there were some affordable strong actuators I could buy.
  11. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    thanks you, but my actuator are not so strong, only 60kg nominal, and 135kg peak. ;)
  12. fzxj520
    fzxj520 Active Member
    1,341Coins
    deep impression! Look forward to your final test
  13. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    Hi, first actuator are finished, the 5 other are almost finished... ;)
    here is some picture:
    • Like Like x 6
  14. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    wow man that it really impressive! The only thing your workshop and mine has in common is the Karcher lol
    • Funny Funny x 2
  15. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    Hi all
    somes new of my project,
    cutting of steel sheet for the base on the plasma cutter of a friend:
    [​IMG][/url][/IMG] [​IMG]
    cutting of all tubes (aluminium for cockpit and steel for base):
    here is my screen pliers:
    I also have cut and bent seat mount, I have another friend who have a bender, yes I have the good friends ;) :
    and now there is the aluminium cockpit, first time I weld aluminium, so it's not art welding but I thinks it will be strong enough
    that' all :)
  16. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    why my picture don't work, in preview it work, but not in post... :(
    154,400Coins
    +11,181 / 57 / -2
    My guess is that there are too many and they are too big.
    You should also insert them as a thumbnail in a post, not a full size image, as otherwise the whole page will time out for anyone on a slow net connection: https://www.xsimulator.net/community/faq/upload-pictures-or-files.81/
  18. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    I tried but it don't work, with only one picture it don't work, picture come from hostingpics. In preview it work but not in final post.
    any moderator or admin can help me? thanks
    154,400Coins
    +11,181 / 57 / -2
    Better to upload them here, rather than rely on an external site, then insert the pictures as thumbnails: : https://www.xsimulator.net/community/faq/upload-pictures-or-files.81/
  20. Gadget999
    12,307Coins
    can you post links to the images ?
