Bastiuscha's 2DOF project
Discussion in 'DIY Motion Simulator Projects' started by Bastiuscha, Apr 15, 2017.
  1. Nick Moxley
    "lost exactness" Sorry not following you on that one.
  2. Bastiuscha
    Bastiuscha Active Member
    750Coins
    You don't have to... you're right :) Was not smart...
  3. Bastiuscha
    750Coins
    Ok this is the first result, of my flex connection. The tube is little bit to long...it's not exact enough... notwithstanding that the tube is relativ stiff. I think, i have to cut it a bit shorter. By the way... the other pot has the same issue! Good, that i found it befor the next damage.
  4. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    The result is clean with the aluminum profile, good job ;)
    The connection potentimeter / motor is original, It doesn't move us to use?
  5. Bastiuscha
    750Coins
    Sry i don't understand "it doesen't move us to use" ? But thanks. :)
  6. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    Sorry for my bad english,
    The flex is glued on the axis of the potentiometer and the motor? Is there a sliding with time during the game?
  7. Bastiuscha
    750Coins
    Ahh ok, no it's not clued. I have not enough experience to say, will it sliding or not. The flex coupler, i installed new, to save the hall pots, for a longer life. I needed many power, to press the flexible tube...i think i will hold, because the pots are very free-moving. If not, i can change that in future.
    Today i cut these for 10-15%... and now, i'm satisfied this the precision!
  8. Bastiuscha
    750Coins
    Hey, now a windy update of my rig. Today my In Line Blowers arrived me.... and it's awesome! What a difference! But for now, i only use 65% of the power. It's to windy for me. haha. It's soooo nice! Can't life without that, anymore.
    But one sad thing....my motion chancellation don't work anymore, since the last steam VR update. :/ Hope matzman666 can help.
    But anyway here pictures of my upgraded rig. :)
    152,627Coins
    +11,087 / 56 / -2
  10. Bastiuscha
    750Coins
    Oh i forgot, that we have here a thread too. :D Now it works! Thank you very much! :thumbs
    Now i had for more than an hour fun with my new wind simulation....yeah! it's so "cool". I hope, i don't get sick. ;D
  11. baxbax
    baxbax New Member
    135Coins
    Sorry @Bastiuscha ,
    but with motors, put in this mode, right motor turn in a sense and left in other?
  12. Bastiuscha
    750Coins
    Not really sure, what you mean... Both motors, work in different directions. Maybe you mean that. :)
  13. baxbax
    baxbax New Member
    135Coins
  14. Bastiuscha
    750Coins
    Ah ok...i don't have a clue about this code. I use SMC... i love it! I can strongly recommend.... Here in my thread you can found informations about that.
  15. Bastiuscha
    750Coins
    Hey....i wanna share my mind with you and mabye you have a opinon for that! I'm thinking about, to use four motors like my ones, instead that cardan joint. What do you think...is my construction to heavy for my idea? My motors at the moment have 65NM (on paper) ....
  16. Bastiuscha
    750Coins
    Hey some news! Now i have a manual shifter and a 5 point belt. The shifter comes with a hinge-joint, for a better boarding, of my rocket. ;-) And the belt is really great. For the immersion, it's a better feeling...i strongly recommend, for drivers without that. I'm really proud now. :)
  17. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Thanks for sharing, I'm doing mine, based on your aluminum chassis.
    Sorry, for my english, its very poor.
  18. Bastiuscha
    750Coins
    It's an pleasure for me, to share my pictures. Nearly extact one year ago, i was planing my motion seat. I was very active here and watched out for other people, how they built it. Everyone found his own solution. And now...after many hours of test driving and improvements, i'm very happy and proud. I can't imagine anymore, to drive without that. To most people drive without....thats sad for me. :)
  19. Bastiuscha
    750Coins
    Hey Mates... a new update from me. Finally i throw out the useless playseat construction! And now, i could increase (really noticeable) the force feeling! For first, i save 7kg+ and the best is, the new vertical balancepoint is 10cm (4inch?!)lower, than before. This is a better improvement, as i thought. And here is a picture of that. If you don't understand exatly, what i did -> compare with my last pictures. :)
    Before you think, the lower platform is to small. I can tell you, it's really ok. The viewing angle of that photo is not good. The lower platform is longer on the backside and the width is much bigger too. I have no problems with a wobble frame. On this picture, you can see better, the lower frame in comparison to the upper frame.
    And some other news...i ordered new motors (smililar to the pgsaw motors) and new contactless hall sensors. I'm pretty happy, that my wife gives me green light for that. xD And i will keep you up to date. :cheers
    • Like Like x 5
  20. Bastiuscha
    750Coins
    And here they are. New motors and sensors.
