The Pivot for Motion.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Fahim, Dec 16, 2008.
  1. Fahim
    Fahim Member
    523Coins
    Dear sirs,
    Pivots are probably required for Motion simulators, sitting under the seat allowing seat to be moved about by a motion unit.
    I have attached a picture.
    The pivot I have seen allow movement left to right and back and forth.
    This concerned me as when the seat is twisted by actuators that there should be atleast 2-3 degrees circular movement so there is no added stress on the motion unit (Actuators).
    Should a pivot be sat on a spindle....
    Kind Regards.
  2. Mr Burns
    Mr Burns New Member
    0Coins
    You can use pivots that are made out of any sort of rubber, it can move in any direction. But you don't want the seat to spin, depending on how you build the frame you can stop it from spinning. Look at frex, it's been used for many years with 2 scn5 actuators, 2 stabilizer rods connected with ball joints to help it not bounce and spin around and just move a little on the balljoints.
  3. XRiccardo
    XRiccardo New Member
    1Coins
    I'm doing a system using a spring.
    For the idea of the rubber.... I am a little doubtful about her duration.
  4. Fahim
    Fahim Member
    523Coins
    Dear sir,
    Please see photo. Are these okay to you use as a pivot.
    You can get these from ebay cheap.
  5. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I have the idea to use such cross joints for my wheel construction. But the cross joint I have in my toolbox for example has play.
    I will try to find one without play tomorrow in our local building center.
    @Fahim
    you could ask the supplier if this crossjoint has any play.
    regards
  6. Fahim
    Fahim Member
    523Coins
    Dear sir,
    I have been to the hardware shop where they sell this:
    There are different sizes: range from small to large:
    I held them in my hand and found out the play is only 1mm approx. Not much.
    Is this dangerous to the simulator if there is no play?
  7. egoexpress
    421Coins
    You need a cross joint with zero play.
  8. Fahim
    Fahim Member
    523Coins
    Dear sir,
    There were heavy duty big size at the shop and they had no play. They were for industrial purpose. Very strong. But a little expensive.
    What happens if thier is play.
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    @ egoexpress
    Youre idea fore your wheel using crossjoints
    Crossjoints have a catch:using them on a angle youre getting sinuswave movement out going axis
    Using 2 crossjoints sinuswave movement will be gone(big angle big sinuswave)
    And give precise the same movement
    Cheap crosjoints surpluscenter.com
    regards AD
  10. tronicgr
    tronicgr
    The play is increased as you get far from the crosjoint to bigger radius. In a distance of 1 meter you may measure 5mm play!!! Not good! You will actually feel the rotation effect!
    Thanos
  11. mohawk24
    mohawk24 New Member
    0Coins
    I would think the use of rod ends would eliminate the stress you are talking about.
    That is what i plan to use..
  12. XRiccardo
    1Coins
    you can post a large jpg of your avatar? Thanks!
  13. mohawk24
    mohawk24 New Member
    0Coins
    are you saying you want me to post a larger pic of my avatar ???
    if yes you can see all of the pics in the other category DIY Motion Simulator projects...
    under thread beginning of my new simulator
  14. mohawk24
    mohawk24 New Member
    0Coins
    as for cross-joints i used a driveshaft taken from a large chevy truck...
    has built-in grease nipples for lubrication and is easily fixed if broken....
  15. Fahim
    Fahim Member
    523Coins
    Dear sirs,
    Land rover universal joint for loweer column. You can buy these from Ebay :)
    Any good?
  16. Ubec
    Ubec New Member
    Australia
    3Coins
    I agree with MoHawk24. A Unijoint of a drive shaft is a good idea imo. You should be able to pick something like that up for very little money...
  17. Fahim
    Fahim Member
    523Coins
    I have bought the above land rover joint which are sold alot on ebay. They cost around 11-15 english pounds. And they have 0 play.
  18. Fahim
    Fahim Member
    523Coins
  19. sn4il
    sn4il New Member
    2Coins
    Do You guys think that a ball head from large tripod would work?
    sn4il
