SMC3 Sabretooth TEST version
Discussion in 'SimTools compatible interfaces' started by RufusDufus, Jan 25, 2015.
  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,199Coins
    You could use SMC3Utils to monitor the Simtools output and see if it looks ok..
    change the simtools interface output to be UDP with port 20017. Use the same output string as for SMC3:
    [A<Axis1>][B<Axis2>][C<Axis3>]
    Then run SMC3Utils and select the UDP Passthrough button.
    If setup correctly you will see the output from simtools (And SMC3Utils will pass the data to the SMC3 arduino)
  2. Intruder
    Intruder Member
    435Coins
    its this problem :
    testet the UDP method : works, so it is related to the serial communication between Simtools and the ard. really strange
    all in all should i use NET + smc3 or SER with 250000 baud?
  3. RufusDufus
    Adelaide Australia
    16,199Coins
    Whatever is more convenient for you.
    Perhaps use the UDP->SMC3Utils to test and setup the motor parameters. Once you have done this you don't really need SMC3Utils anymore so you could then just change the .ino baud rate and use direct serial from Simtools.
    If you discover anything more let me know - I would really like to understand what is happening. :think
  4. Intruder
    Intruder Member
    435Coins
    Will do so ! By the way, a really big thank you for your excellent work with this tool and your fast response! It really helped me!
    Thanks a lot!
    When I find the problem for my solution I will let you know ;)
  5. Pit
    30,482Coins
  6. Mauro
    Mauro New Member
    Catania
    177Coins
    3DOF, DC motor, SimAxe, Arduino, SimforceGT, Motion platform, 4DOF
    desperate until I can not make my simulator go.
    Synulator with 3 dof mechanics
    X-plane software + simtools + arduino one + smc 3 + n.2 sabertooth 2x32
    Unfortunately I can not enable the serial port of arduino n. 12 and engine 3 does not work.
    You can help me?
    I would be very grateful
    Best wishes
    Mauro
  7. Pit
    30,482Coins
    Better you use the SMC3 modification by @BlazinH , since he optimized the code especially for the Sabertooths. https://www.xsimulator.net/communit...rial-pid-motor-driver-w-softstart.9277/unread
  8. Mauro
    Mauro New Member
    Catania
    177Coins
    Thanks for your advice. We hope well.
  9. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
  10. Mauro
    Mauro New Member
    Catania
    177Coins
    Grazie Gigi davvero molto gentile,
    appena riesco a vedere le pagine che mi hai mandato, spero che risolva il problema.
    Grazie ancora
  11. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Provalo vedrai che funziona e soprattutto è molto facile! Try it it works perfectly and it's very easy
  12. shaman
    shaman 2dof sim
    Moscow
    - 964Coins
    Hi.
    where to see the connection diagram 1 Arduino Uno + 2 Sabertooth 2x32 ?
    to connect 4 motors.
  13. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
  14. shaman
    shaman 2dof sim
    Moscow
    - 964Coins
  15. BlazinH
    16,661Coins
    Simtools has several serial interfaces so just use another arduino and put 2 motors on each one to get 4 total.
  16. shaman
    shaman 2dof sim
    Moscow
    - 964Coins
  17. BlazinH
    16,661Coins
  18. shaman
    shaman 2dof sim
    Moscow
    - 964Coins
    where to download work sketch for 4 motors?
    sorry for my English
    151,443Coins
    +11,038 / 56 / -2
  20. Pit
    30,482Coins
    And why not using just two Arduinos?
