Question hall 360 degrees
Discussion in 'Electronic and hardware generally' started by evolaco, Jan 17, 2018.
  1. evolaco
    evolaco Member
    Spain
    694Coins
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    You can not reverse the polarity in the hall. The software I think I had an option to invert the meaning to the engine 1, it was in the first lines.
    No puedes invertir la polaridad al hall. El software creo que tenía una opción de invertir el sentido al motor 1, estaba en las primeras lineas.
  3. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Here it is, line 13
  4. evolaco
    evolaco Member
    Spain
    694Coins
  5. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    i think you mean line 13. line 9 are for the H-Bridges
  6. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
  7. evolaco
    evolaco Member
    Spain
    694Coins
    Reverse only motor 1?
  8. BlazinH
    16,689Coins
    It's much simpler to just reverse the positive and negetive leads to the motor. Then if motion is backwards on that motor change the direction check boxes where needed in Simtools.
