Tutorial SCN5 Wiring Tutorial
Discussion in 'SimTools compatible interfaces' started by nclabs, Jun 19, 2014.
  1. noorbeast
    154,580Coins
    +11,190 / 57 / -2
    Are the Actuator IDs set to 0: https://www.xsimulator.net/community/faq/actuator-ids-must-be-set-to-0-here-is-how.241/
  2. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    i have now my SCN5 to ID 0.
    But this will not works.
    In the Output test i havent move from the Actuators.
    154,580Coins
    +11,190 / 57 / -2
  4. danone38
    danone38 New Member
    - 291Coins
  5. danone38
    danone38 New Member
    - 291Coins
    Can you tell me how to reverse the run of a scn5 worm.
    I try with simtools with the orange boxes but it does not work.
    There is dyadic software but I can not do it either.
    Yet my id is 0.
  6. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    The orange boxes in simtools should do the trick !!
    I havent used my rig for months..... but i remember me having the same problem for movement direction.
    be sure that you run calibration for each game after you have setup simtools.
    (this is to determine the min / max values on your specific setup !!)
    (do this for each game you run)
    regards,
    Renoboss
  7. jite
    jite New Member
    - 83Coins
    2DOF, SCN6
    Hello, thanks for your job. I need to inverse direction of my SCN6 actuators (apparently not possible with Simexperience software) Inverting PIN4 and PIN2 will do it?
    Thanks for answer
    Joël
  8. that_is
    that_is New Member
    China
    207Coins
    Do I HAVE to wire the ILK to a stop switch?:roll
  9. yobuddy
    51,676Coins
    As I understand it, there is actually 2 versions of the SCN floating around.
    Some require the ILK to be powered for the actuator to enable.
    Some require the ILK to be unpowered.
    So it just depends on the type of SCN you have.
  10. FrankXX
    FrankXX New Member
    6Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Arduino, JRK
    Ťhanks for sharing,i'm trying to figure this out.
  11. Rasul
    Rasul New Member
    94Coins
    2DOF, SCN5, Arduino
    I'm bulding 2dof simulator with 2 SCN5 actuators now.
    I wired everything like it's described here. Except I used built in Arduino USB to serial converter and then connected it to rs485 transceivers. I used a digital out of Arduino to manage max485 working mode dynamically and this part is working fine.
    When I trying to connect to those actuators using TBVST visual setting tool I got message "Communication error (#0601). Make sure communication port selection and axis number".
    I attached a pic with communication timings during connection watched through oscilloscope. Yellow is data sending to actuator and blue is from actuator. It seems like it's fine. I have no idea what I did wrong.
    Can anybody help? What else I can do?
  12. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Hey there. I'm just putting together a parts order for a SCN5 2DOF build. I've never used a zener diode before... what is its function in the SCN5 power circuit? Do I require a specific wattage?
  13. pasquereau
    pasquereau New Member Gold Contributor
    6Coins
    Hello
    I have a question I have a 3 dof simulator from prosimu 2 scn6 at the front and one for the loss oftraction I just bought a kit 4 cylinders srt 80 lebois racing that I installed on my chassis and I would like to keep the scn6 for the loss oftraction I currently have the version prosimu/simtools 3 can I put with 2 interfaces one serial and the other snc to operate my 5
    cylinders?
    If not, with simtools v3 I've tried the 4 srt 80 in serial works without a problem, but in scn with the same parameters as in prosimu/simtools v3 on the same port, it doesn't work, what can I do?
    Am I obliged to use a rs485 usb converter? I have the impression that it does not recognise port 3Thank you for your feedback.
