vthinsel
Project Cars 2 UDP (uses new UDP format) - Manual plugin start 1.1
Project Cars 2 UDP for consoles
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    vthinsel submitted a new resource:
    Project Cars 2 UDP (uses new UDP format) - Project Cars 2 UDP for consoles (and PC)
    • Like Like x 8
  2. STEELJOCKEY
    STEELJOCKEY New Member
    AUSTRALIA
    441Coins
    Quick question, this plug-in means data can be output from the console version of Project CARS 2 using UDP, and a PC can read the output data and drive a motion platform for the console game?
  3. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Short quick answer : yes
  4. STEELJOCKEY
    AUSTRALIA
    441Coins
    Brilliant. Looks like my dreams have come true. I’m guessing there is more needed than just this plug-in.
  5. patoch
    patoch l'AUvergnat de france Gold Contributor
    63000 clermont ferrand
    21Coins
    3DOF, SCN6
    comment récuperé le bon plugin pour que le jeu marche moi jai reçu cela pCars2. 2.0.4 et le pCars.2.0.1.0 ca me dit no valide aider moi svp
    153,770Coins
    +11,149 / 57 / -2
    You can dual language post but need to include English via Google Translate, particularly when you are looking for assistance, see the forum rules here: https://www.xsimulator.net/community/threads/forum-rules.9527/
  7. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
  8. Radioproffi
    Lviv
    1,677Coins
    We are running into an issue. when two PCs are in same subnet and use UDP PCARs plugin SimTools on Both PCs are driven from PCARs game on First PC. So SimTools on both PCs are getting telemetry over UDP from one game instead of each other only from local games corresponding. Looks like UDP propagate all over LAN instead of localhost only . It is a nature of UDP?
    Looks like it is impossible to change port in PCARs and in plugin DLL.
  9. fuad
    fuad New Member
    kuwait
    23Coins
    Hi @vthinsel
    thanx for the plugn...
    the gamedash working fine but the gamevibe is not working for PC2 it shows in the profile editor that the plugin supports the game vibe but when i start the game nothing shows in the gamevibe window...can you help please ??
    BTW LFS working fine
    cheers
  10. yobuddy
    51,529Coins
    I think it's a bug, hope to knock it out this weekend.
    Take care,
  11. fuad
    fuad New Member
    kuwait
    23Coins
    @yobuddy thank you waiting for the fix
    regards.
  12. yobuddy
    51,529Coins
    @fuad,
    I could not find any bugs.
    I used Value1's PC version and it worked just fine.
    So I expect this one would also.
    Take care,
  13. fuad
    fuad New Member
    kuwait
    23Coins
    thank you dear it is working fine now i just needed to set the H/L values in the tuner.
    regards.
  14. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Guys, I need your help.
    After getting the DIY license I installed the Project Cars2 Plugin UDP to get it work with my PS4.
    My rig is currently in an "optimisation" mode, so I tested the setup with PC2, Simtools and the Plugin without the rig hardware.
    Unfortunately, it seems that I get wrong data.
    Pls see the videos:
    In the first, LFS is launched and you see the virtual axis when the car is driving and finally stopped somewhere on the track.
    --> there is hardly any movement on the axis when stopped. So far, everything ok
    In the 2nd video, but now witch PC2 running on PS4:
    --> a lot of movement on the axis, even when car is standing still.
    So it seems that I get wrong values somehow.
    In PC2 I setup the UDP frequency to 1 (but tried also with other values) and the format is "Project Cars 2".
    In a wireshark trace you can see, that the data is arriving:
    So, what's wrong ?
    PS4 and PC are in the same subnet and both connected via Ethernet.
    Any ideas ?
    Thanks,
    Dirk/Arazok
  15. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Hello. In tuning center, make sure you capture max/min. It is too blury in you video but I suspect the range is too small, explaining the erratic movements.
    EDIT: I looked more carefully th video. the values for heave/sway/surge/roll/pitch/yaw move nicely in tuning center, so the issue looks to be really on the min/max values.
  16. Arazok
    Arazok Member
    Computer scientist
    783Coins
    ok, thanks for the hint. Could be, that I never saved min/max values for PC2.
    I will check tomorrow.
    153,770Coins
    +11,149 / 57 / -2
  18. Arazok
    Arazok Member
    Computer scientist
    783Coins
    ok, I will do that.
    Do you advice to create a motion profile with a disconnected rig / seat, so that axes cannot move accidently in a wrong way ?
    153,770Coins
    +11,149 / 57 / -2
    No, you should ensure the rig moves as SimTools expects before messing with any game profiles: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Once you have a reasonable Default profile there should not be too many issues with really wild movement, unless a game has 0 for all values in the Tuning Center, and that is easy to check for when you first install a plugin.
  20. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Thanks for your help. Recording with Tuning Center and saving the data solved the issue :)
    But still one question: In Simtools GameEngine you create the default profile and then a profile for each game.
    In the GameManager you select the Game and you start Tuningcenter to once record the Min/Max values for this game.
    But when exactly is the default profile then taken and how to capture min/max for default ?
    cheers Dirk
