Question plugin update issue
Discussion in 'SimTools Plugins' started by Gelatin, Jan 29, 2018.
  1. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Could anyone help me about plugin update?
    One of my friend can not update any plugins, because the system does not let him drop plugins into updater.
    The Gameengine and Game Manager is closed, so it should work.
    What can couse such a problem like this?
    He has an Entertainment license of Simtools 2.2, the PC was clean, never had any version of simtools ever before.
    The software is communicate with LFS, but I can not realise what could be wrong with updater to install any other plugins.
    Any idea?
    Help me pls
    And actually He has an other issue as well. He made an acocount here too, but he can not write any post or open a new thread.
    That's why he asked me to help him and ask you guys,
    Thank You!
    154,580Coins
    +11,190 / 57 / -2
    While there are some limitations on a new member they can post, just not some things like links, which is to prevent spammers.
    By any chance are you trying to install SimTools 1.3 plugins into SimTools 2, as that will not work.
    Did the plugins come from theXsimulator.net download page, as these are for SimTools 2: https://www.xsimulator.net/community/marketplace/
  3. yobuddy
    51,675Coins
  4. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    This could be the problem. I gonna find out what kind of plugins he has.
    The Simtools is active, licensed, so
    Thank you, actually I did not know that simtools 2.2 has different version of plugins.
    Thanks for your quick reply!
  5. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    Unfortunately still not working...
    :confused:
    I downloaded right plugins again, but same issue.
    I can not put plugins into updater...
    Simtools well licensed:
    It looks good, but not:
    :sos
    154,580Coins
    +11,190 / 57 / -2
    Did you make sure game engine and game manager were shut down prior to running the plugin installed application?
  7. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    yeap. Sure.
    154,580Coins
    +11,190 / 57 / -2
    So when you drag a plugin zip file on to the plugin installer app can you please be specific about what happens and and messageds that are displayed.
  9. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    When I drag zip file and I wanna drop into updater than nothing happens. I got a tipical windows sing (a circle crossed) when I pull over it.
    I have a simtools software as well, but I've never had problem to add any new plugin.... have no idea.
  10. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    ok, I cleaned up his pc, removed Simtools and all components of it.
    Just finished with reinstall as administrator. Activation done. It looks everythin ok.
    Closed Simtools software and opened updater.
    tried to drag n drop all of downloaded plugins with same result.
    Same issue.
    He has Win10 pro 64bit on his PC and he can not communicate to anyone on forum
    154,580Coins
    +11,190 / 57 / -2
    Perhaps @yobuddy can make other suggestions but I would suggest uninstalling and accept removing all files.
    Then to be sure delete the appdata SimTools folder if it exists: C:\Users\your_user_name\AppData\Local\SimTools
    Then do a clean reinstall of SimTools 2.
  12. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    did it 10 minutes ago.
    Cleaned up the PC and of course I deleted all of components and files of simtools included that appdata path.
    no effect, same problem...
  13. yobuddy
    51,675Coins
    You will have this problem If you run the SimTools Plugin Updater as administrator.
    Launch it normally and it will work buddy.
    Take care,
  14. Jolly
    Jolly New Member
    Hungary
    211Coins
    Here we go! Problem solved.
    It is work, so Simtools does not like administrator force.
    I learned something again :)
    Thank you so much guys!
    Thank you Yobuddy!
    Have a nice day,
  15. Jolly
    Jolly New Member
    Hungary
    211Coins
    May I ask that how long is this limitated period about new posts for new members?
    Actually my friend can not post anywhere, he's got not just any limitation about links or something...
    He just wanted to introduce himself as he read that in forum :)
  16. noorbeast
    154,580Coins
    +11,190 / 57 / -2
  17. yobuddy
    51,675Coins
    The 'Drag 'n' 'Drop' not working makes sense when you think about it.
    If the plugin updater is running as admin, it is running above the privilege of the account your using.
    So it blocks the 'Drag 'n' 'Drop' because the current user does not have the same elevated privileges as the plugin updater.
    Take care,
