Question 2DOF sports seat
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by xiatian, Jan 31, 2018.
  1. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Started playing with a laptop, now for the desktop, the new win7 system, the other are normal, that is, into the game seat does not move, not into the game test, the seat can move. Looks like the two software is not connected .. Game Engine / Game Manager. NET4.0 are loaded
  2. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    ip address is also set.
  3. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    I'm not good at English, using Google Translate, I hope to get help, any suggestions are good, thank you!
    152,373Coins
    +11,076 / 56 / -2
    Please post pictures of all of your settings, including your Interface Settings
  5. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello there. noorbeast
    This is setting
      129 KB
      542
      119.1 KB
      540
      130.4 KB
      551
      177.2 KB
      546
      147.1 KB
      516
      143.2 KB
      539
  6. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    No problem testing
    Seat dynamic,
    Into the game will not move.
    152,373Coins
    +11,076 / 56 / -2
    Did you run LFS for a a lap or two before patching, as that generates some needed files. If not unpatch LFS, shutdown SimTools, run a couple of laps in LFS, restart SimTools and repatch LFS.
    Does Game Manager turn blue when LFS is running?
    Your Main Level at 20% is way too low, for now put it back to 100%.
    Why the Axis Limiting, are you using SCNs?
  8. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    In this case, the seat can move.
    When playing in a notebook is 20%. After changing the computer is also set at 20%.
    Not SCN5. The original DIY seat.
    I will try now.
      157.7 KB
      505
  9. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello .noorbeast
    Great, a success. It feels good moving up. Thank you very much, thank you!
    In addition, I would like to ask, I use a worm motor, the shaft without restrictions?
      119.1 KB
      679
  10. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello .noorbeast
    Now I put 20% transferred to 100% into the game moment very fierce, almost throw me out, can not play, do not understand why.
      143.2 KB
      501
    152,373Coins
    +11,076 / 56 / -2
    You need to learn how to refine a motion profile for your rig and the game you are playing, see the steps here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Capturing the Max and Min in the Tuning Center will make a big difference, but you also have to get the Axis Allocations right and tweak the Tuning Center Values, once you have a good generic profile you can refine it further with different profiles in Game Manager.
    It takes a bit of time and patients but gets easy with practice.
    With worm DC motors you don't need axis limiting.
  12. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello: noorbeast
    I have opened the shaft limit to 100%. Level 60%. Action is fierce.
    I think it is not SMC3Utils settings are not good?
      71.7 KB
      557
  13. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    This is my collection of data,
    Manually adjusted.
      154.3 KB
      544
