Lauching finally a 3DOF (seat mover) instead 6DOF low cost dynamic simulator
Discussion in 'DIY Motion Simulator Projects' started by Oms, Feb 4, 2018.
  1. Oms
    Oms known as "Doc6dof"
    France Colomiers
    - 173Coins
    DC motor, AC motor, Arduino, Motion platform
    Hi guys,
    sorry I will finally simplify my project (6dof) to a simple seat mover (3dof), because the room where I can place the simulator is finally much smaller than the room I had initially reserved for that...
    So do not consider all the following discussion...:)
    I will finish this seat mover (I think I am very closed to), but I have a dream: build
    a compact 6dof (stewart platform) + partial home made G-Seat + VR and with degrees of freedom around +/-30° for pitch/roll/yaw and around +/-20cm for surge/sway/heave... I do not know if it is realistic:grin
    _____________________________________
    Initial project (6dof):
    after several months of reflection, having changed several times the concept, I launch now my project...
    As a good video is better than a long discourse, I let you see my short movie and I look forward to have your opinions, questions, advises. Thank you in advance
    152,373Coins
    +11,076 / 56 / -2
    Thanks for sharing your project and intended approach.
    A couple of comments to consider.
    You won't need 6 Arduinos to drive your rig, as an Arduino can control more than one motor, see here for code choices: https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    It looks to have up to around 40 degrees roll and pitch, that may look impressive but likely may have speed and power issues for anything other than gentle flight simming, there is also a lot of mass to control.
  3. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    Very unusual build, I cant wait to see it progress.:popcorn:thumbs
  4. Oms
    France Colomiers
    - 173Coins
    Hello noorbeast,
    thank you for you relevant comments. I tried effectively to reduce the number of arduino, but unfortunately, with the architecture I would like to implement, too much pins are needed (for example juste for analog input: feedback, current, tachymeter, an 3 adjustable resistor to read for Proportional, Integrale, Derivative value, that will not be adjusted by soft). I am currently writing the header of the software, where you will find much more detailled explanations. In anycase arduino boards are not very expensive so I do not try to optimize the number of boards.
    Concerning the required power for the rig movement, I am not sure effectively I will have enough power with enough fast movements. I hope thatwill enough enough for flight simulation, and I will use in this case only the seat moving for car races... In fact I do not know what will be the performance, taking into account that:
    The rig weight will be around 150kg (including the pilote), and it will be almost balanced (using the center of gravity + a garage door spring) but not totally (because cable drive can work only in one direction…), with the aim of reducing the required power. It is easy to find used washing-machine universal motors for about some hundreds Watts to 1 kiloWatts. With this kind of motor, and without limitation, the spin speed increases very rapidly to 10 000 and more rpm (it is the reason I have to measure the current and thespin speed thanks to the tachymeter present in these motors). The gear ratio in insure by classical steel endless screw + barrel nut (diam 10 or 12 mm ?), surrounded by a PVC conduit (to prevent grease projection) with a slot all along for the mechanical crank link (ball bearing slide). Sure I will have a lot of adjustement and clarification to make when I begin to test my simulator...
  5. Oms
    France Colomiers
    - 173Coins
    Me too Fluke I would like to finish rapidely. I think severals months will be required. I have begin to weld the cockpit, I will send photos in a future post.
    152,373Coins
    +11,076 / 56 / -2
    The link I provided has different Arduino code you could use, have a look at the SMC3 code, as it also has a handy graphical program for managing settings.
  7. Oms
    France Colomiers
    - 173Coins
    Hi, I had a look on SMC3 arduino code, that seems interrested. PerhapsI can divide by 2 the number of arduinos.
    152,373Coins
    +11,076 / 56 / -2
    Sure can :thumbs
  9. Gadget999
    12,035Coins
    are you running the motors AC ? how do you swap direction
    i suggest you get an arduino and program it and get a motor running to get familiar with the smc program
    have you decided on the ballscrew and threads ?
  10. Oms
    France Colomiers
    - 173Coins
    I will use washing-machine universal motor, so in 220v ac, but normaly this kind of motor accepts also dc. To swap the direction, you have to swap the 2 terminal connections of the stator, or the 2 terminal connectors of the rotor (the rotor and the stator are connected in serie).
    I have also began to write the arduino code, but from scratch
  11. Gadget999
    12,035Coins
    interesting the motor will accept DC - does it use brushes ?
    how many volts DC will the motor need ?
  12. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @Gadget999
    By separately powering the stator and armature windings he is turning an AC universal motor in to a DC sepex motor.
    A sepex motor is basically a DC brushed motor but uses a coils (electromagnet) instead of permanent magnets on it's stator.
    Yes, an universal motor has brushes and commutator on it's rotor.
  13. Oms
    France Colomiers
    - 173Coins
    I think you have answered to you own questions...,
    concerning the voltage in dc, I suppose it is the same than in ac (so 220v in my case). I will use a diode bridge to transform 220ac in 220dc, and not added high capacitor because that would increase this voltage about to 320v with risk of damage (motor overvoltage). Then I will use a full bridge (mos or igbt) for a PWM power control
  14. Oms
    France Colomiers
    - 173Coins
    For your information I have created a specific post in the good place (actuators and drivers) so I will not continue to describe this part of my project in this current post, but in the new one:
    https://www.xsimulator.net/community/threads/powerful-and-low-cost-220v-motor-driver.11627/
  15. Oms
    France Colomiers
    - 173Coins
    From drawing to reality: I had some availability this week-end, so here after a first component (base of the cockpit)...
  16. Oms
    France Colomiers
    - 173Coins
    Hello all,
    I am available this afternoon, so I will make the seat pivot, which is a part of the seat mechanism, then I will send you photos by this evening...
  17. Oms
    France Colomiers
    - 173Coins
    Hi, I have well progressed on the seat pivot, but no finished...
  18. Oms
    France Colomiers
    - 173Coins
    Hello all,
    some news, the design is changing (version 2 ). Mainly the base (to provide large movements pitch, roll, yaw-traction loss) is rethinking : use of 220v monophasis hoist (my concern is how to control the speed of asynchronus motors). I have also decided to implement a triple head. The first test with a gt1060 6g overclocked and rfactor are very good (I paid the 2 19'' 4/3 screens 25 euros each one...),
    see you...
  19. Oms
    France Colomiers
    - 173Coins
  20. Oms
    France Colomiers
    - 173Coins
    Hello DYI men/women,
    little by little my Xdof dynamic simulator takes shape, here after the last photos ...
    see you
