Question Actuator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by xiatian, Feb 6, 2018.
  1. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello everyone
    I am preparing my 3DOF sports seat project, plan to use the worm motor for the actuator, the forum did not find a similar thread, before the start, I hope to get some advice, any suggestions are good, thank you very much !!
    This is my design.
      114.1 KB
      601
  2. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Use springs to increase lift.
  3. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    English is not good, with Google Translate. This design is very simple, but also reduce noise. Hope that experienced friends can give some advice. Thank you!
  4. RandomCoder
    Control Engineer
    1,674Coins
    What is the reason for choosing to use a chain? Would a belt be quieter and cheaper?
  5. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Fear the belt is not strong enough, only to choose the chain, if we can find a suitable belt, I will use.
  6. MarkusB
    4,215Coins
    Maybe you find some inspiration on this site: http://bffsimulation.com/linear-act.php
  7. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thanks MarkusB
    Browse the above page to find the software is different with SimTools. Before seen such a photo of the actuator, originally from this site, thank you very much!
  8. Gadget999
    12,132Coins
  9. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thanks Gadget999
    However, this shaft drive is not suitable, can not use the spring to increase thrust.:)
