Question problem with game vibe
Discussion in 'SimTools Pro & Entertainment Version' started by hellpanzer, Feb 11, 2018.
  1. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    hello have take the last plugin dirt rally with gamevibe support but i can do anything
    i just see gamevibe 1 , gamevibe 2 ... no rpm
    nothing to setting
      278.1 KB
      867
  2. yobuddy
    51,524Coins
    Unless you post screen shots of your settings, there is no way for us to help you buddy.
    Are you using SimTools v2.2?
    Have you connected it to the running game once?
    It will not show the labels for the game until you connect it successfully one time.
  3. hellpanzer
    hellpanzer Member
    93Coins
    3DOF, DC motor
    ok i see , when the game is run .I can setting gamevibe
  4. yobuddy
    51,524Coins
    Excellent!
    Take care buddy,
  5. riton
    riton Active Member
    1,006Coins
    GameVibe and Assetto, there's a bug, it shows me "GameVibe 5" windows, or "GameVibe 4", an idea about this problem?
  6. yobuddy
    51,524Coins
    Hi @riton,
    This happens when there is a parsing error.
    Please make sure you on SimTools v2.2 and the newest version of GameVibe or you will get this for sure.
    Also the newest GameVibe needs a clean installation for everything to work as usual.
    (btw, this parsing error check will be removed from the final version.)
    (it's here for the beta to check for parsing errors.)
    Take care,
  7. riton
    riton Active Member
    1,006Coins
  8. yobuddy
    51,524Coins
    On the Game Manger splash screen buddy.
    Please try with a couple of games to see if they all do the same thing buddy.
  9. vin100lorant
    vin100lorant New Member Gold Contributor
    Professeur Electrotechnique
    Beynes
    191Coins
    Hello, I allow myself to come back on this problem of alert message of game vibe. As far as I'm concerned, I still have the problem with the Dirt Rally plugin.
    I'm using simtools v2.3.1 and game vibe beta 5.
    I tried to change the region in windows 10. but it's worse, the game engine goes into a trance!
    A clue to solve this problem?
    Thank you in advance for your concern
    153,734Coins
    If there is an error message please post a picture of it.
  11. vin100lorant
    Beynes
    191Coins
    Sorry, indeed I stayed on the riton problem about the popup message "game vibe3" thinking that in my question it would have been induced.
    It is therefore the small window that is displayed indifinently (each time the value of the collision effects vary) with the message "game vibe3" (or 4 or 5, etc ....).
    I could see on the forum that there was a language manipulation to change in windows 10 in the region options. But it does not solve the problem at home (Worse, my game engine is crazy my simulator, I was forced to return to the region-> French).
    An idea?
    153,734Coins
    Sorry, I understand you have tried the language settings to English Local, but I do not understand your description of the Game Vibe issue, Can you please post a picture.
  13. vin100lorant
    Beynes
    191Coins
    Indeed, without image it is complicated. As a new forum user, I had to post 3 replies before I could send one.
    So here.
    This is displayed each time the "collision" effects change.
    And so it blocks the work of game vibe.
  14. yobuddy
    51,524Coins
    It because you need to change the region buddy.
    If USA English does not work, try UK English.
    The pop up means its unable to decipher what is being sent.
    Take care,
  15. vin100lorant
    Beynes
    191Coins
    Bad luck, the problem still appears (especially gamevibe3, gamevibe4 and a little gamevibe5).
    I tried to configure the language France, English (US) and English (UK) with and without the box to coher "Beta".
    I have not found anything else on the net that could help me apart from a question of separator character ...?
    Curious, no?
  16. yobuddy
    51,524Coins
    @vin100lorant,
    I am preparing a test this week to solve this problem once and for all.
    If you want too, PM me sometime this week, and I will send you some test files to see if we can fix this on the app side of things.
    Take care,
  17. vin100lorant
    Beynes
    191Coins
    Thanks, i'll do it.
    Tell me if you need more information about my windows configuration, or anything else that will help you better understand.
