DiRT Rally Plugin [Deleted]
Discussion in 'SimTools Plugins' started by llluis, Jan 24, 2018.
Thread Status:
Not open for further replies.
  1. llluis
    Quebec
    1,632Coins
    Rally only.
  2. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    Did you made any progress in finding the problem ?
  3. Jymä
    Jymä Member Gold Contributor
    Finland
    184Coins
    No, I didn't figure out any way to get it working. I'm waiting for Assetto Corsa plugin to test next. My coins have run out again though :blush
    I was thinking it keeps loading default GameVibe state for Dirt Rally which has GameVibe1, GameVibe2, ... instead of RPM, Gearshift etc and that would be why it gives an error. Because one time it had reset my GameVibe profile for Dirt Rally by itself. But it's just a guess no logs or anything to support.
  4. yobuddy
    51,651Coins
    It's defiantly a parsing problem where you get a popup with GameVibe#.
    I would check that your CPU is not tapped out at 100%.
    Next, please try another game plugin.
    Testing a run with Live for Speed would tell us a lot.
  5. llluis
    Quebec
    1,632Coins
  6. llluis
    Quebec
    1,632Coins
    Please try the updated version to see if anything changes. I could not reproduce the issue but found a potential error.
  7. baykah
    Toulouse - France
    414Coins
    Tested, not working, same behavior
  8. Jymä
    Finland
    184Coins
    I can confirm the issue still exists, but I found a workaround. On Windows 10 you can search Control panel (Win+S).
    It must be connected to decimal format or something on additional settings, I didn't test which setting is causing it. But you can reproduce it by changing the format to some European country. I remember SMC3 used to have the same issue with SimTools.
  9. llluis
    Quebec
    1,632Coins
    Perfect, this is good info.
    I'll look at it. Thanks!
  10. baykah
    Toulouse - France
    414Coins
    nice fouding, it was it for me too
    I switch on langage parameter in my win7 the decimal indicator from , to . and it worked :)
    I have windows in french and the standart parameter is ","
  11. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I'm struggling to get any of the new plugins to work. Game manager just crashes with the error below. Not sure if I'm doing anything wrong. All previous plugins seem to work fine for me but Dirt 4 and Dirt Rally now produce this error.
    Any ideas?
    Cheers :)
  12. baykah
    Toulouse - France
    414Coins
    I had to delete the old plugin for rally, I went to the good directory and deleted every thing
    After that, I reinstalled the new plugin and It worked
    • Informative Informative x 4
  13. Sarge
    - 181Coins
    Thanks, I'll give that a try later :cheers
    Update: That worked. Thank you very much for pointing me in the right direction :)
  14. baykah
    Toulouse - France
    414Coins
  15. Oliver Wallner
    Oliver Wallner New Member Gold Contributor
    - 133Coins
    Hello, I do not get a surge to run with the Dirt Rally Plugin. In all other simulations he works, in the output test the command works too. Also, a new installation of Dirt Rally and the plugin has brought no solution. When testing in Tuning Center while driving values are also written in the tuning center while driving, but the effect does not come on. Roll, Pitch, Heave works, but not Surge. Can someone help here?
  16. noorbeast
    154,334Coins
    +11,179 / 57 / -2
    Temporarily disable other Axis Allocations and just do surge, then each of the other forces/axis in turn: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  17. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Same problem here with surge. Seemed to work fine with the plugin prior to game vibe update. I get a very small reading every now and then in tuning centre but it is basically not working.
  18. Phil Barnes
    Phil Barnes New Member
    - 104Coins
    Trying to use this plugin to get my Wind Mod working with DirtRally - anyone here manage it? TIA
  19. jinho
    jinho New Member Gold Contributor
    - 627Coins
    when I started dirt, the simulator shakes unregularly a lot. Seating on the seat is really hard. I cannot see the same problem here. Is there anyone who gets the same problem?
  20. yobuddy
    51,651Coins
    try this,
Thread Status:
