SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. Nick Moxley
    Can you replicate this back to back ? Very interesting if so.
  2. yobuddy
    51,659Coins
    I have never ran it as administrator thou?
  3. Ringorumble
    Ringorumble Active Member
    190Coins
    For me it works only as administrator, if i start without "as adminsitrator" i can setup vibe / Setup soundcard and test everything, but no vibes in iracing. Start as admin, vibes in iracing :)
    BTW a friend which does his own software told me that there is a value in the Iracing Plugin which only output the hz value when you drive over a curb (complete isolated) .. maybe interesting for the plugin
  4. yobuddy
    51,659Coins
    Please try running it as normal.
    But only startup GameVibe after your in the game and on the track.
    Please let me know if it starts up as normal buddy.
  5. Ringorumble
    190Coins
    I tried this before, when game was started and values were send , motion was going and then i started Gamevibe . it crashed ...
  6. atbc2
    atbc2 New Member
    argentina
    - 127Coins
  7. yobuddy
    51,659Coins
    You don't want a speaker thou, as it will make a bunch of strange sounds.
    We only want the vibrations from the unit, that why we use transducer's.
    With that said, I believe you can DIY transducers out of old woofers if you really wanted too.
  8. atbc2
    atbc2 New Member
    argentina
    - 127Coins
    I'm going to do the test, let's hope it can be :grin
  9. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
  10. Leandro Kemp
    Brasil
    - 10Coins
    I had seen the game vibe near the tunning center, but now I can not see it anymore. Where do I access the game vibe setup menu?
  11. atbc2
    atbc2 New Member
    argentina
    - 127Coins
    you mean the tuning center of Game vibe ?.
    If that is the case, with a right click on the Game vibe icon, it appears there.
      18.7 KB
      797
  12. Leandro Kemp
    Brasil
    - 10Coins
    for me only appears tunning center and game engine
  13. llluis
    Quebec
    1,632Coins
    That's the the Game Engine, not Game Vibe.
  14. Leandro Kemp
    Brasil
    - 10Coins
    For me no game vibe appears anywhere. That is the problem.
  15. llluis
    Quebec
    1,632Coins
    It's worth asking: did you install it and started it? You have to do it manually and separately from other SimTools apps.
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  17. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Screenshot_20180221-032859.jpg You can also use the tuning centre button from the main game vibe window
  18. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    no plugin update for prepar3d v4?
  19. paulopsx2
    brasil
    648Coins
    ok some new problem here. try to use on ASSETO. ok.. all working fine, engine, dash, manager and vibe gives me a feedback on tunning center, see rpm runs, and crashes, etc etc.. but no vibrations on cockpit. I test all transducers, on sound test, and its ok. Try to put game vibe on admin rights, and vibe crashes... close. its weird. try some crazy tests and returns here. If anyone have a solution, please, put here ( i read all posts on this thread, none of solution )
  20. paulopsx2
    brasil
    648Coins
    ko.. some ( rapid ) news. AND NO SUCCESS at all.
    try to run gamevibe after runs asseto... car on track... again.. all dashs, and all works, includes wind, movements.. tunning center on, works and show all ok. But no vibrations in game. In other atempt, try to run at the same conditions but with admin rights.. and simvibe crashes again. The long night are coming. rs.. still try solve the problem.
