value1
pCARS2 Plugin 2.0.5.4
SimTools game plugin for pCARS2
  1. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    I will do a new test with GameVibe-B40
  2. DoubleM
    Amsterdam
    - 23Coins
    Same problem
  3. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    I managed to get numbers into vibe tuning but that was only by clicking mute on all the vibes
  4. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    got it working now had to put Shared Memory and UDP Protocol Version on Project CARS 1
    Edit:- I also had to turn game manager off and back on once game loaded.
  5. value1
    15,029Coins
    Hmmm, the plugin is supposed to work with the Shared Memory Project CARS 1 and Project CARS 2 – not with UDP though…
    (It doesn't matter what UDP protocol you select)
  6. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    You are correct UDP protocol isnt important (just did a quick test) but it only works for me with Shared Memory Project CARS 1
    I also you have to switch off and back on the game manager once the game loads.
  7. Lol4
    Lol4 Member
    Australia
    - 115Coins
    With Game Vibe I can only get sounds from the sound card assigned to "Sound Card 2" I have tested by configuring each physical sound card with "Sound Card 1" and "Sound Card 2". Each one works fine when assigned to sound card 2 so ruled out a physical sound card issue. Also Dirt Rally works fine so think it is possibly PC2 plugin related. Is anyone else having this problem?
  8. Jakub
    Jakub New Member
    Ireland
    - 29Coins
    3DOF, Arduino
    Yeah, also can't get it to work. No issues with Dirt or LFS.
    Only once been able to see something in tuning center but even then couldn't feel a thing...
    Removed/reinstalled plugin and all settings file I could find for both ST and GV few times but still no luck.
    Doesn't look like GV is even recognizing game start...
  9. Lol4
    Lol4 Member
    Australia
    - 115Coins
    @Jakub - I had to use the following procedure to get it going
    Reboot computer (I neede to do this if I have been running other games with GV and was important step)
    Load SimTools Game Engine and Game Manager but NOT Game Vibe
    Load PC2 Game
    Enter a practice session (or whatever) and make sure car is moving on track
    Turn off main toggle in Game Manager
    Run/Open Game Vibe as Administrator
    Game Vibe may error (if it does close Game Vibe down and re open again as Admin)
    Turn on main toggle in Game Manager
    Then I had sounds and data to Tuning Centre as expected. I still however only have configurable sound through "Sound Card 2" which I think may be a different issue.
  10. Jakub
    Jakub New Member
    Ireland
    - 29Coins
    3DOF, Arduino
    Still no joy :/ Did all as described and can see data in tuning centre but nothing works.
    Strangly all worked fine on ce when unpatched the game, removed plugin and went through all the steps again.
    Rebooted PC, launched all and nothing again.
  11. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    Thank you.
    Any chance Somebody could give some coins please.
    I just used mine on a week to get all no vibe support plugins other week.
    152,081Coins
    +11,065 / 56 / -2
    Done...have fun and please report back on how you go.
  13. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Thank you very much, it is more appreciated than you imagine.
    time to try gamevibe!
  14. DoubleM
    Amsterdam
    - 23Coins
    There is data in plugin 2.0.5.2
    But.. no sound to the buttkicker.
    Sound card settings are correct. I can do some tests of sounds in the card settings and also when i use Vibe Creator.
    Still no sound in the game.
  15. DoubleM
    Amsterdam
    - 23Coins
    I have still problems getting this plugin to work with GameVibe. Who is using GameVibe with pcars2 ?
  16. Lol4
    Lol4 Member
    Australia
    - 115Coins
    I have it working ok but start game vibe when on track and I some times need to turn the main on/off toggle on game manager a few time before vibes come through. Also sometimes it crashes game engine on start but I restart it and it gets going after a few on/off toggles
  17. DoubleM
    Amsterdam
    - 23Coins
    So, too many issues. Not user friendly. I will use SimCommander 4 for now.
  18. noorbeast
    152,081Coins
    +11,065 / 56 / -2
    Game Vibe is marked as being in Beta for good reason as it is a brand new SimTools feature, with far more scope and game coverage than alternatives, but it has only been accessible for a few months.
  19. DoubleM
    Amsterdam
    - 23Coins
    Exactly, a developer needs feedback. I don't see much feedback per game plugin etc. For example GameVibe is working great for NoLimits.. There is a problem with the combination GameVive / pcars2 plugin. I will test the plugin and give some feedback when a new version arrive. I see this positive. Keep up the good work!
  20. value1
    15,029Coins
