Question 3DOF complete freedom
Discussion in 'DIY Motion Simulator Projects' started by Nibe, Feb 19, 2018.
  1. Nibe
    Nibe New Member
    78Coins
    Hi all,
    before starting explaining my idea little bit about myself: I'm an old computer engineer and I always enjoy playing car sim videogames (since Accolade's TestDriver!). Even if I have very low experience with hardware I want to try to create, for fun and learning, my own simulator.
    I have red almost all the documentation, and I understand a lot even if other things are still in the dark for me, hopefully moving on with my idea I'll fill the gap.:)
    My idea is to build a 3dof complete freedom motion sim where Roll, Pitch and Yaw shall move 360° using 1 motor per axis.
    Due to the weight I was thinking to use Arduino + Sabertooth dual 32A or 60A version and DC motor around 1,5Kw with brakes. I already design an sketch of my idea, with the help of a friend of mine.
    The M1-M2-M3 are the motors and where they should be attached, my apologize for the draw, it's just a draft.
    My question is, does SimTool support 360° with 1 motor per axis?
    I know it sounds weird as project but thanks a lot for any good advice, I'll start to post some pictures as soon as I'm sure I can do ithug:
  2. MarkusB
    4,215Coins
    Hi @Nibe,
    in the first sentence of your post you mention that you enjoy playing car sim video games.
    So if this is your main area of interest, why are you planning such a complex 3x360 degrees simulator?
    As mentioned in many threads here, fast movements are more important for a racing simulator than large movements. A seat mover would probably result in better immersion and would surely be much easier to build than what you currently have in mind. :)
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
    reminds me of a joyrider configuration. m1 is usually on the same plane as m2 (offset 90 degrees). you will get the same movement.
  4. Nibe
    Nibe New Member
    78Coins
    @MarkusB thanks a lot for your reply, indeed I'm a big fan of sim car! I'd like to build it like that because I'd like also use it with a flight simulator, which actually I'm a big fun of as well :)
    @bruce stephen thanks for the advice, I'll take a look at the joyrider simulator. So it seems possible to use SIMTOOL with 1motor per axis
  5. Nibe
    Nibe New Member
    78Coins
    I decided with a friend of mine who is a carpenter to start to build the mechanical part, while I'm trying to figure out if i can use sim tool with 1motor per axis, here some picts to share :) Of course is a long way ...
  6. BlazinH
    16,689Coins
    Simtools works fine with one motor per axis as you put it but it doesn't output over 360 degrees total rotation on a given axis. So if you want your sim to do multiple rotations you have to program that aspect into a motor controller yourself or do it via an extension or custom plugin to SimTools.
    But I'm not sure your design is good for over 360 degrees anyway because motors 1 and 3 will gimbal lock when motor 1 axis is pointing upwards or downwards. What are your intentions?
  7. FargusFaustmeister
    FargusFaustmeister Member
    Engineering Technologist
    69Coins
    Holy moly that is a big gear ring. Are you designing around that component because you already had it or did you go and purchase it?
  8. Nibe
    Nibe New Member
    78Coins
    sorry guys for the delay, and thanks a lot for your feedback:
    @BlazinH thanks for the hint. I'm very happy that simtools can work with one motor per aixs. And it's fine if it will be not able to do a whole 360 degrees for the moment, once I'll understand better all the things i'll try to program it into the motor controller or create a plugin as you suggested. I hope you can help me on this to point me in the right direction.
    The motors are indipendent in the movement, there are 3 rotary joints to pass electricity and data. I know the draft was not really clear, my apologize, I'll try to post more clear information later once I finish the next stage posting more picts
    @FargusFaustmeister well I had it already, let's say it was a part of a machine that my friend, the carpenter, already had, indeed it has some pros and cons. I will describe later on once I complete the next stage.
    Now I'm waiting to receive a Sabertooth dual 60A, I have already a couple of arduino mega/uno ready to be connected. And now comes the hard part where I don't know really much even if i try to read the documentation, starting from the simtools configuration till the software runinng on arduino which of course must be modified, I guess, but I'll bother you guys for help later on.
    For now starting from the very beginning, SimTools - Game Engine Axis assignement, I have, already, some doubts on how configure it, in my case we are talking about Roll/Pitch/Yaw, if im not wrong, but I dont' get how should I select them. Should be something like this:
    Axis1 DOF1 Roll
    Axis1 DOF2 Roll
    Axis2 DOF3 pitch
    Axis2 DOF4 pitch
    Axis3 DOF5 yaw
    Axis3 DOF6 yaw
    Again my apologize for te stupid question.
