My DIY 2DOF almost finished!!
Discussion in 'DIY Motion Simulator Projects' started by Ratafia82, Feb 26, 2018.
Do you like it?
  1. Yes
    4 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. Ratafia82
    Ratafia82 New Member Gold Contributor
    Catalonia
    87Coins
    Hello everybody!
    This is my first post in this community and I am glad to show you my 2DOF project!
    I have to finish putting some fans to the motors and a new case to support the wheel and avoid the middle stick. For now, I will show you the images of the process and my 2DOF almost finished!!
    IMG_20180107_220732_HHT.jpg IMG_20180107_220744_HHT.jpg IMG_20180107_220801_HHT.jpg IMG_20180108_211326.jpg IMG_20180108_212628_HHT.jpg IMG_20180124_233448_HHT.jpg IMG_20180130_220649_HHT.jpg IMG_20180130_220703_HHT.jpg IMG_20180207_213649_HHT.jpg IMG_20180210_203632_HHT.jpg IMG_20180210_203701_HHT.jpg IMG_20180211_122355.jpg IMG_20180223_212012_HHT.jpg IMG_20180223_215231_HHT.jpg IMG_20180223_215254_HHT.jpg IMG_20180223_215618_HHT.jpg IMG_20180223_215635_HHT.jpg
    Yuhuuuu!!
    I have played in Live for Speed with the demo of simtools and it's very fun!!!
    If you want some details of my building you can post a question!
    Bye guys!!
    • Like Like x 6
  2. Daguru
    Kitchen installer
    Wales uk
    467Coins
    Motion platform
    would love to see a video of it in action:popcorn
    and congrats on the build:cheers
    152,373Coins
    +11,077 / 56 / -2
    Thanks for sharing your rig.
    What PSU(s) and motor driver are you using and what code is running on the Arduino?
  4. Ratafia82
    Catalonia
    87Coins
    Here you have! My first test with LFS and simtools in Demo mode:
    I requested a full edition of simtools to test with other games. When I have it I will post more videos!
    Thank you for your congratulations!:rolleyes:
  5. Ratafia82
    Catalonia
    87Coins
    Hi!
    I used the SMC3 Arduino 3DOF Motor Driver shared in this community. I follow the guide of RufusDufus, and I enter the mode 2 using the SCM3.ino code for Arduino since I use IBT-2 H-bridges to control the motors. The PSU(s) are two different PSUs connected in series this way:
    One of them is a PSU from a PC with 250W (I think) and 15-16 A, and the other is an HP PSU with 200W aprox. and 15A aprox too. I don't remember now exactly the W and A of PSUs but I am sure that they are different. If you need more details I can tell you all the characteristics of the PSUs when I arrive at home. Bye!
  6. Ratafia82
    Catalonia
    87Coins
    I have to say that the movement are soft because I set 50% of amount of axis in simtools. However the sensations in the rig are very impressive. I have to adjust to 70-80% of amount of axis and test if the motors can withstand the effort. At 50% the motors are hot but not too much. My problem with the temperature of motors is when I stop to play and I stop the simtools software. In that moment, the motors are hotter (Very very hot) compared when they are running with me on the rig. Anyone knows what are happening? I don't understand. My solution right now is to switch off the motors after stop the software to avoid overheating. But other solution would be better if I knew the real problem (configuration in Arduino? bad configuration in simtools software?) Thank you for your help!!
    152,373Coins
    +11,077 / 56 / -2
    Great to see your rig in action :thumbs
  8. MythoRex
    MythoRex New Member
    111Coins
    Molt currat Ratafia!
    Very good
  9. MythoRex
    MythoRex New Member
    111Coins
    A question, Ratafia...
    Why did you decide put the engines in front instead of behind?
    Is it for some reason?
    Thank you!
  10. RacingMat
    21,054Coins
    motors have to be at a "good" length from the center of rotation.
    they can be front or back :
    by putting the motors in the front, the rig is more compact
    152,373Coins
    +11,077 / 56 / -2
