My 2dof motion office chair
Discussion in 'DIY Motion Simulator Projects' started by Ijanen, Feb 15, 2018.
  1. Ijanen
    Ijanen Living Room Mechanic
    precision mechanic, media designer
    Germany, NRW, Halver
    408Coins
    Hello all!
    I decide to start with my Projekt.
    I have bought an arduino uno and a motor shield and built a simple test platform.
    After changing "L<Axis1>R<Axis2>" to "L<Axis1a>R<Axis2a>" in the interface settings
    in the game engine i get it working in the output testing.
    Then i tested it with data from live for speed and it seems to work well so i can start to
    built my sim.
    At first i want to built it like that.
    But first a simple version for further testing than upgrade it with better materials.
    After that i want to upgrade it to this version.
    And maybe in the future i want to add a yaw axis.
    Sty tuned for furtehr updates.;)
    150,037Coins
    +10,993 / 54 / -2
  3. Ijanen
    408Coins
    Thank you for the tip i will keep that in mind. The problem is i have to built it
    compact because of less room space. I already have the wipermotors
    so i try them first. When that doesnt´t work i will buy bigger ones.
  4. erivx
    erivx Member
    Ecuador
    206Coins
    2DOF, Arduino, 4DOF
  5. Ijanen
    408Coins
    Thank you, but i already have everything i need. At this time i built the motion module
    with mdf plate i found at home and some parts from the hardware store. When everything is
    as i want it to be i will upgrade it with other materials.
  6. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    ull 100% need bigger mate i built a very similar setup as a seat mover and thats without the pedal and wheel setup you have planed.. it worked great yes but you could do more than 3 dirt rally stages without it getting hot from the load ..so having the pedals and wheel mounted to it will work them pretty hard.. noting under 100watts..
    i might be wrong but yours look like 70watt motors
    i used these first
    https://www.motiondynamics.com.au/worm-drive-motor-12v-70w-45-65-rpm-6-35nm-torque.html
    then ended up using these
    https://www.motiondynamics.com.au/zd1633r-12v-100w-30-55-rpm-8-50nm-torque-left-angle.html
  7. Ijanen
    408Coins
  8. ericRacer
    Pilot
    Canada, Quebec
    949Coins
    you should think locking the wheels , with this design you will throw in all directions ! and if you want saving money, buy the right motors at the beginning as noorbeast advice you . you will not regret it . just my 2cents
  9. Ijanen
    408Coins
    I have thought of that and will probably remove the wheels and replace them with a plate.
  10. Ijanen
    408Coins
    I have bought an original arduino board and a monster moto shield clone.
    It seems to be okay. Could not measure it because my multimeter
    is broken. And i use a 12V 360W 30A power supply.
    First i choose to stack the two cards. Maybe i will wire it in a later version.
    For the cooling, I take an old boxed fan for AM3 socket and sawed
    through the cooling fins, so that it fits.
    I also ground isolate the Motors.
    I knew the blue cabel is for low speed so i cut it from position 1
    and i cut the ground from position 2 and soldered them together.
    So i have only 2 cables coming out of the motor.
    And i have build a plate for the motors and electronics
    and one for the seat.
    Now i still waiting for the u-joint parts to arrive.
  11. Ijanen
    408Coins
    Can I also use hall sensors on an Arduino? I read that you should prefer 10k ohms pots.
  12. erivx
    erivx Member
    Ecuador
    206Coins
    2DOF, Arduino, 4DOF
    Of course you can use it and they have more precision. And if something goe wrong, nothing breaks
  13. ferslash
    ferslash Active Member
    4,798Coins
    i did not understud... if you want to stock arduino and moto monster you will need to change the arduino program... will you make changes? or how are you planning to use it?
    best regards
    fer
  14. erivx
    erivx Member
    Ecuador
    206Coins
    2DOF, Arduino, 4DOF
    Hey whatsaa.
    Look, you're right if you want to use monster and arduino, you have to use one type of arduino code and wiring. And the same if you use JRK; you have to find the correct software for your desing and hardware. Luck
    150,037Coins
    +10,993 / 54 / -2
  16. Ijanen
    408Coins
    @ervix thank you that sounds good. At the moment i use the pots because
    i have them laying around from another projekt, But will by hall sensor
    s for the upgrade.
    @ferslash i dont know what you mean. What do i have to change in the code.
    I use racing mats code and you can use it for both variations wired or stacked.
    As far as i know. I did not change anything and it works fine.
    @noorbeast thank you for your info.
  17. Ijanen
    408Coins
    The universal joint parts arrived today. :)
    • Like Like x 5
  18. ferslash
    4,798Coins
    sorry about the confusion :D
  19. insanegr
    insanegr !N$@n€
    Athens
    16,720Coins
    do you mind sharing the links for the u joint you bought.
  20. Ijanen
    408Coins
