Help to create plugin for FURIDASHI: Drift Cyber Sport
Discussion in 'SimTools Plugins' started by AntonGTR, Mar 12, 2018.
  1. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    I'm Anton Ulyanov - FURIDASHI: Drift Cyber Sport game developer.
    Our game available on Steam Store.
    Could You help us with SimTools plugin for our game?
    We try to create the best simulator of drift racing and now we are implementing motion platform support.
    We will strongly encourage all our customers to use SimTools
    Our game send the data via UDP to localhost(127.0.0.1) port 20782.
    struct
    uint32_t signature; // allways 0xA394143F
    uint32_t game_id; // allways 0x0F
    float pitch; // forward-backward angle in radians
    float roll; // left-right angle in radians
    float headings; // angle of rotation around the vertical axis in radians
    float acc_longitude; // acceleration along the longitudinal axis, in g
    float acc_latitude; // acceleration along the latitude axis, in g
    float acc_vertical; // acceleration along the vertical axis, in g
    } MotionData;
    We can provide Steam key for each person who can help us.
    Thank You!
  2. value1
    14,239Coins
  3. yobuddy
    51,532Coins
    Appreciate the support guys!
  4. value1
    14,239Coins
    Here we go :)
    Let me know if it works for you, please.
    What would be especially nice for a drift simulation was local lateral speed to calculate traction loss. Can you add that to the output data (UDP stream)?
    And if you could add speed, RPM, gear (and possibly the position of the four suspensions) that would be nice for GameDash and GameVibe ;)
    Fun game to play, BTW , I can practice drifting without risking costly damages:cheers
  5. SeatTime
    How good is this :thumbs. I will have to go look it up on steam now :).
  6. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Great!
    I have run Plugin Updater and have add your zip file to it.
    But I can not select imported plugin in Game Manager.
    Please help!
  7. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Send you Steam key via PM.
  8. value1
    14,239Coins
    Are you running the demo version of SimTools? The demo only shows LiveForSpeed. You'll need at least the DIY version. @yobuddy can certainly help here!
    153,824Coins
    +11,150 / 57 / -2
    Are you using the demo version of SimTools? If so it will only work with Live For Speed, as that plugin is included specifically for testing purposes.
    Congrats on your game and in seeking to provide motion support.
    153,824Coins
    +11,150 / 57 / -2
  11. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Yes, I'm using demo version of SimTools. I asked for DIY version of @yobuddy.
    Steam keys giveaways for Sim Tools community
    FURIDASHI: Drift Cyber Sport keys:
    Q3YZH-EW6QJ-X6IKM
    DDWE9-RG3EV-BT25X
    63EPR-L5DTY-RVELX
    T4NDR-YFYEE-WRP48
    WR768-E5HL2-T0A2H
    W007Y-VKT7P-YMF3D
    B0DDZ-D6PA3-43GCF
    PV97E-FR732-LTZN0
    VFK6R-DWXRC-KECAZ
    XEEMD-L88I2-BZ77M
    Premium Cars Pack#1 Steam keys:
    TBVPF-ZCJWT-DXPI3
    IBRWW-ZLYW7-A8QRI
    CCNVB-NXNZ3-6EEDG
    TFEMP-E2WYE-9JQ6G
    MPFVC-ZX47H-3B3FW
    KRZ0F-2J5IW-HD8JI
    8TYZL-V0X7P-WQKA7
    22HFM-2F0Y2-XPKVV
    K9FEG-7G4Y7-RWV79
    3YZPP-F5ITX-60TGQ
    • Winner Winner x 7
  12. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Could you explain what is GameVibe and Game Dash? And how it works?
  13. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Yes, we can add any data. May be anything else?
    153,824Coins
    +11,150 / 57 / -2
    Giving away the Steam keys is exceedingly generous of you and deeply appreciate, I used:
    Q3YZH-EW6QJ-X6IKM
    TBVPF-ZCJWT-DXPI3
    Game Dash allows the game to drive peripherals like digital and even real dashboard gauges and lights: https://www.xsimulator.net/community/marketplace/simtools-v2-game-dash.76/
    Game Vibe has just been added to SimTools and is still in Beta but it allows a game to drive cheap to expensive transducers like Buttkickers, and to tune the vibration to represent just about anything: https://www.xsimulator.net/community/threads/simtools-v2-game-vibe.11359/
  15. Nick Moxley
    New drift game.....Interesting.
    I used XEEMD-L88I2-BZ77
    and K9FEG-7G4Y7-RWV79
    Thansk Anton YOU DA MAN COOL GUY!!!!!!
  16. yobuddy
    51,532Coins
    @AntonGTR
    Discount code for a free Pro license sent via the PM you sent buddy.
    Take care man!
  17. marlon
    marlon Active Member
    1,070Coins
    thanks
  18. value1
    14,239Coins
    GameVibe is an app to drive transducers ("butt-kickers") that can simulate relatively high frequencies like vibrations from the motor, etc. (see here)
    GameDash is an app, that can display telemetry data and drive e.g. a speed-driven fan to simulate wind (for examples see here)
    The values above are vital.
    Of course there are plenty of other possible values: Times, damages, tyre wear, slip, pressure, temperatures (brakes, oil, water, tyres, etc.), fuel, ABS, ESP, clutch, throttle, flags, driver info, track info, status info, etc. etc. etc.
  19. SeatTime
    Is the Game VR capable?
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Says on steam that VR is to be added
