Help to create plugin for FURIDASHI: Drift Cyber Sport
Discussion in 'SimTools Plugins' started by AntonGTR, Mar 12, 2018.
  1. Daguru
    Kitchen installer
    Wales uk
    467Coins
    Motion platform
  2. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Hey,
    Thanks to yobuddy for Professional License!
    I have tried the plugin and test with Output Testing>Virtual Axis.
    It seems that everything works OK. But I do not have the equipment to check in action.
    Can someone test and leave a review?
    We can add the necessary data such as speed, RPM, gear and the position of the four suspensions. But let's define their format.
    struct
    uint32_t signature; // allways 0xA394143F
    uint32_t game_id; // allways 0x0F
    float pitch; // forward-backward angle in radians
    float roll; // left-right angle in radians
    float headings; // angle of rotation around the vertical axis in radians
    float acc_longitude; // acceleration along the longitudinal axis, in g
    float acc_latitude; // acceleration along the latitude axis, in g
    float acc_vertical; // acceleration along the vertical axis, in g
    //the new_begin
    float traction_loss; // 0..1 - IS THIS AN ANALOG OF TYRES SKID SOUND VOLUME?
    float suspension_0_height; //front right wheel // 0..1, 0 is minimum height, 1 is maximum height - IS THIS OK???
    float suspension_1_height; //front left wheel // 0..1, 0 is minimum height, 1 is maximum height - IS THIS OK???
    float suspension_2_height; //rear right wheel // 0..1, 0 is minimum height, 1 is maximum height - IS THIS OK???
    float suspension_3_height; //rear left wheel // 0..1, 0 is minimum height, 1 is maximum height - IS THIS OK???
    float speed; // >=0 in kmh or mph (in game settings) - IS THIS OK???
    float RPM; // 0..1 OR 0..8650 - ???
    int32_t gear; //1-6 gear = 1..6; N gear = 0; R gear = -1 - IS THIS OK???
    //the new_end
    } MotionData;
    152,373Coins
    +11,077 / 56 / -2
  4. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
  5. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    152,373Coins
    +11,077 / 56 / -2
    Sorry about that, I have updated the FAQ direct download link.
  7. yobuddy
    51,105Coins
    Hi @AntonGTR,
    One really cool thing about SimTools is it was built to wrap around the game.
    Instead of the game having to wrap around SimTools.
    Meaning "float suspension_0_height; //front right wheel // 0..1, 0 is minimum height, 1 is maximum height" would be fine, as we can scale the input to anything SimTools requires in the plugin itself.
    With that said thou I do see a couple of observations that may make it easier for a plugin to be made.
    Traction loss technically is the difference in the way the vehicle is heading the the direction it is traveling.
    Most likely this is how you drive the skidding sound?
    Let me let @value1 chime in here as his math skills are > than mine.
    I'm not quite sure what he was looking for here and I don't want to tell you the wrong value.
    float suspension_FL (-1000 to 1000 would be perfect.)
    float suspension_FR (but anything is useable)
    float suspension_RR
    float suspension_RL
    Yes.
    GameDash has the ability to use 'Edit Commands' to translate it to anything the user wants for output.
    For instance, if the output was in kmh, then we would use this Edit Command:
    MATH * 0.621371 (and we would get Mph.)
    The same value shown on the dashboard of the car.
    0..8650 or wherever the vehicle tops out.
    Yes, either is fine as GameDash can make Edit Commands to replace the R with a -1 and the N with a 0. And GameVibe sees the R as a -1 and the N as a 0.
    (but N gear = 0; R gear = -1 probably makes thing easier for the user overall)
    Hope this helps buddy!
  8. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Hey!
    We have updater version on Steam!
    Now available 2 formats of telemetry data. Please see below.
    struct
    } MotionDataFormatA;
    struct
    float traction_loss; // 0..1 - this is an analog of tyres skid sound volume
    float suspension_FR; //front right wheel // 0..1, 0 is minimum height, 1 is maximum height
    float suspension_FL; //front left wheel // 0..1, 0 is minimum height, 1 is maximum height
    float suspension_RR; //rear right wheel // 0..1, 0 is minimum height, 1 is maximum height
    float suspension_RL; //rear left wheel // 0..1, 0 is minimum height, 1 is maximum height
    float speed; // >=0 in kmh or mph (in game settings - Gameplay>Units)
    float RPM; // 0..1 // 0 - engine min RPM, 1 - engine max RPM
    } MotionDataFormatB;
    Please modify the plugin and test it. Is everything OK?
    Can someone record a video of how the game works on the simulator - we would be happy to add this video as a trailer to Steam.
    Big Thanks to SimTools community!
    Additional giveaways of Steam keys.
    FURIDASHI: Drift Cyber Sport Steam keys:
    ZFDER-TVXJR-0QEA5
    DCT54-ZDN7P-AGPXL
    7ERLH-MF3TP-BG4R6
    LAWDD-5N22N-3JC2K
    CY046-AIEZ0-TPJCY
    Premium cars pack#2
    NV3CK-74VA5-K38G3
    DWMCN-2AJT4-CHX9I
    93BFH-7GEKV-VREHX
    C0BDT-RHEMQ-H8NZC
    RAXBI-KG39G-7HCI9
    FQEYK-9L8CE-TLJLQ
    7LRVF-QIELH-IAQ6H
    A4ILV-6TMNZ-T2TF5
    T7NGI-I60HL-FD2G5
    Z6IHY-40ZQ7-HFW4H
    • Winner Winner x 5
  9. Daguru
    Kitchen installer
    Wales uk
    467Coins
    Motion platform
    Awesome !!!
  10. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    thanks for the steam keys giveaways:thumbs
    i used
    7ERLH-MF3TP-BG4R6 and
    93BFH-7GEKV-VREHX
    MPFVC-ZX47H-3B3FW
  11. value1
    15,054Coins
    Here we go: Updated with the additional data structure.
    The plugin works with Format A and B.
    Feedback welcome!
  12. yobuddy
    51,105Coins
    Thanks for the keys @AntonGTR! :thumbs
    I used: Z6IHY-40ZQ7-HFW4H
  13. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Thank You all!
    Please add FURIDASHI: Drift Cyber Sport to plugin list.
    Can I get plugin source for internal testing?
    And can I get SimTools logo to use it in the game to show our players that FURIDASHI supports by SimTools?
  14. value1
    15,054Coins
    Hi Anton
    I've added the plugin to the resources and in the plugin thread.
    Attached you also find the source for the plugin.
    Thank you so much for your support. A pleasure working with you :cheers
  15. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Wow, thanks @AntonGTR for the keys :thumbs
    I have used:
    T4NDR-YFYEE-WRP48
    CCNVB-NXNZ3-6EEDG
  16. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Thank you very much!
    I used CY046-AIEZ0-TPJCY and T7NGI-I60HL-FD2G5
    Installing right now (and waiting for VR support)!
  17. Historiker
    9,208Coins
    I cannot comment on the game (yet) but I do want to mention that this is the best game dev/motion community outreach that I have seen. Thank you very much for talking directly to the community to help develop your game.
    I wish all game developers were this forward thinking.
    @AntonGTR, well done! :thumbs
    • Agree Agree x 3
  18. AntonGTR
    AntonGTR New Member
    Moscow Russia
    240Coins
    Thank You all guys!
  19. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    thank you.
    i used W007Y-VKT7P-YMF3D
    and
    8TYZL-V0X7P-WQKA7
    cheers!
  20. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    478Coins
    Hi!
    Great handout from a game developer... I snached code WR768-E5HL2-T0A2H
    Thank You!
    Addition: used also code: 7LRVF-QIELH-IAQ6H
