Question Assetto Corsa Suddenly Started Crashing Game Engine
Discussion in 'Assetto Corsa' started by AussieStig, Feb 16, 2018.
  1. AussieStig
    AussieStig Member
    207Coins
    Hey mate, thanks for the suggestion, I have tried that, I completely deleted AC from my PC, deleted the remaining Steam Library AC folder and My Documents folder. Installed AC from scratch with exactly the same outcome. Game Engine stops working once any circuit begins to load. Actually I have tried pretty much everything short of wiping Windows and starting from scratch. Just seems so drastic to have to reinstall an operating system because one plugin is not working. SimTools is creating the null point exception according to the error reports, also syswow64 has something to do with it, it keeps popping up in the reports as well. Cheers mate, AussieStig
    152,541Coins
    +11,085 / 56 / -2
    Out of curiosity is Assetto Corsa set to 32-bit or 64-bit mode? The plugin was updated to handle both a while back but if your is set to 32-bit then try setting it to 64-bit.
    Even so I still consider it is more likely a hardware/usb or .Net related issue. Perhaps @yobuddy has some other suggestions.
  3. AussieStig
    AussieStig Member
    207Coins
    Cheers mate, I will check that 32 or 64 bit setting. I have uninstalled NET.Framework and reinstalled it. Yes Yobuddy has been helping as well, but we both dont seem to be bale to resolve it. Cheers, AussieStig
  4. AussieStig
    AussieStig Member
    207Coins
    Hey Noorbeast AC is set to 64bit, force 32bit is not ticked. Tried it anyway didn't make any difference mate. Checked the error again, SimTools Game Engine is throwing a second chance exception error. Which is just baffling. Cheers, AussieStig
  5. Mu-KwangKim
    South, Korea
    - 689Coins
    C:\Users\<user>\AppData\Local\SimTools\GameEngine\MaxMinProfiles
    Have you checked the files in that folder?
    Sometimes I get a .net error when I change to an empty file.
    I check these files when I get a .net error.
  6. AussieStig
    AussieStig Member
    207Coins
    Hey mate, thank you for your tip. Much appreciated, are you saying there may be empty files that do not belong in that location which are causing the .net error? What should be in there normally? It would be awesome if it is as simple as removing empty files :) Look forward to your reply, cheers mate, AussieStig
  7. Mu-KwangKim
    South, Korea
    - 689Coins
    First, copy the other file and change its name.
    Open the file and modify '<_GameName> name </ _ GameName>' part.
    Normally, you just type in the file name.
  8. AussieStig
    AussieStig Member
    207Coins
    OK, a little confusing, would it be too much trouble to shoot me a screenshot of what you mean? Cheers mate, AussieStig
  9. Mu-KwangKim
    South, Korea
    - 689Coins
    Do you want this screen?
    If you run simtools from a Windows startup program without using the launcher, you may get the same error.
      417.1 KB
      929
  10. AussieStig
    AussieStig Member
    207Coins
    Ta mate, I always start SimTools from the desktop icons. Thank you for the screenshot as well, so the image is of the content of the min/max folder in that location. I will check that out. Cheers mate, AussieStig
  11. AussieStig
    AussieStig Member
    207Coins
    Big shout out to YoBuddy, we have finally rectified the issue with my Game Engine quitting while loading a circuit in AC.
    It turns out that there were two files I needed to delete from Game Profiles and Game Engine which once done were re-built by SimTools.
    I started Game Engine and manager and behold, the ProSimu made some noise in place of the Windows Error Game Engine has stopped working.
    Very grateful to everyone that chipped in and tried to help. Cheers AussieStig.
    PS: Does anyone have really good max min AC settings for the ProSimu T1000 3DOF?, as mine were wiped with this resolution.
  12. joe extraknow
    joe extraknow Member Gold Contributor
    1,550Coins
    I have the same problem you had. Would you please tell me which two files to delete?
    thanks
    Joe
    PS: I send you a PM too.
  13. noorbeast
    152,541Coins
    +11,085 / 56 / -2
  14. joe extraknow
    1,550Coins
  15. Andrzej
    Andrzej New Member
    Poland
    61Coins
    I had the same situation. Removing all the "assetto" files from ...\AppData\SimTools and reinstalling plugin solved it!
    Thanks Guys!
  16. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    38Coins
    Maybe windows defender or anti virus
  17. Anthony Morris
    Multi trade
    Essex UK
    38Coins
    And I would look at anti virus fails in this manner :)
  18. Anthony Morris
    Multi trade
    Essex UK
    38Coins
    So did you ever fix this, what was it, I had a similar prob it was anti virus defender
  19. joe extraknow
    1,550Coins
    I just re-installed the SimTook. This fixed it.
