4 DOF (PITCH-ROLL-TRACTION LOSS-SURGE)
Discussion in 'DIY Motion Simulator Projects' started by Enrico, Mar 11, 2018.
  1. Enrico
    Enrico Member
    417Coins
    4DOF
  2. Enrico
    Enrico Member
    417Coins
    4DOF
  3. Enrico
    Enrico Member
    417Coins
    4DOF
    tomorrow will instal the cards box and some parts more to paint..
    153,788Coins
    +11,150 / 57 / -2
    I am enjoying following your build progress but you don't need a separate post for each picture, that just makes your thread a chore to scroll through, so please consider putting more information and pictures together in future posts.
  5. Enrico
    Enrico Member
    417Coins
    4DOF
    WP_20180325_18_11_11_Pro.jpg WP_20180325_18_12_09_Pro.jpg WP_20180325_18_13_14_Pro.jpg WP_20180325_18_10_51_Pro.jpg
  6. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody, this is the way I connect the pot to the motor shaft, of course I will cut the screw to the lenght required
  7. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody, after a very long stop I'm restarting. Here the very first movements (without feedback) :cheers..
  8. Enrico
    Enrico Member
    417Coins
    4DOF
    ....sorry, the file is too big , I will try to load on you tube and put the link.
    Sorry again
  9. Enrico
    Enrico Member
    417Coins
    4DOF
    ...must be here
    ...I hope
  10. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    Check that engine that makes a weird noise
  11. Enrico
    Enrico Member
    417Coins
    4DOF
    Add some picture of how I connect the pot. Maybe can be usefull for someone....
    WP_20180425_11_00_58_Pro.jpg WP_20180425_11_05_14_Pro.jpg WP_20180425_11_05_36_Pro.jpg
    Today I tested both motors with Pololu software and play with positions and PID :cheers Now its time to download Simtools and try to move. :grin
  12. Enrico
    Enrico Member
    417Coins
    4DOF
    ...forgot a question...
    Can someone explain me how to use a joystick to move the rig?
    Thx
  13. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    There is a generic Joystick Plugin, if that is what you mean: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    Or use one of the many flight sim games that have SimTools plugins.
    But you don't need a plugin or joystick at all to just move the rig, you can do that with SimTools in Output Testing.
  14. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi guys, I finally finish my sim
    I already move the motors with jrk and seems to be ok.
    Right now I have downloaded simtools and now will ask for activation code. After that I think will need your support ...:)
    Thx
    153,788Coins
    +11,150 / 57 / -2
  16. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody,
    here the first movments of my rig with LFS.
    • Winner Winner x 3
  17. Enrico
    Enrico Member
    417Coins
    4DOF
    :grin:cheers..maybe the movments are a little to hard but I have to refining the motion profile.
    I have a question .
    When I start with LFS everything is ok but after some laps the rig lost the right level. I mean the center position of the right motor became different respect the left one (it hangs to the right).
  18. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    There are a range of possible factors that may be affecting the motor.
    I am assuming the PSU is not tripping out.
    So check the balance of your rig.
    Your lever CTC hole distance may be too big.
    You may also need to refine your PID settings.
  19. Enrico
    Enrico Member
    417Coins
    4DOF
    The PSU work well no problem with it . The rig lost the level but it continues to work
    the balance seems to be ok
    Later I will try to refine the PID
    Will try also a test changing the CTC
    THX a lot for your support :thumbs
  20. titomaky
    181Coins
    Motion platform
    Hi friend, I suggest you check the position of the right potentiometer in case it is wrong. A greeting.
    Hola amigo, te sugiero que revises la posicion del potenciometro derecho por si estuviese mal fijado. Un saludo.
