Recommended hardware setup for GameVibe
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MarkusB, Feb 9, 2018.
  1. MarkusB
    4,215Coins
    Dear GameVibe experts,
    I went through the GameVibe Manual with all its valuable configuration information.
    But since I have absolutely no experience in using butt kickers / bass shakers, I would appreciate some information on a recommended hardware setup.
    Ideally this would cover the following aspects:
    • Recommended amplifiers
    • Recommended crossovers, if needed
    • Recommended bass shakers
    • Schematic wiring of a multi bass shaker setup, including sound card <-> amplifier(s) <-> crossover(s) <-> bass shakers
    I saw the list of hardware from @Lol4, but did not find any information on the wiring aspects. Either I have overlooked it or it is considered too trivial to be mentioned. :)
    Thanks a lot in advance!
    153,764Coins
    +11,149 / 57 / -2
  3. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Well... I received my amp, and the 4 shakers. Now the question is where I could fit them on my "not 2 DOF yet" rig:
    Would the orange spot do the job ?
    I'm currently printing a case for the amp, and I'm also planning to make an isolation for the shakers :
    Any comments ? I'll post soon other pics of all vibe hardware I plan to use.
    Cheers
  4. Lol4
    Lol4 Member
    Australia
    - 115Coins
    I would attach as close to your body as possible. I cut out foam from seat base and have two tucked underneath in there in a diy custom made timber holder, they don't seem to overheat and you don't need them on full volume to get a good rumble. Leaves room for tuning between games and profiles
