SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. Historiker
    9,205Coins
    You might have the Oculus to automatically change default audio when it starts up. This could change the device order and make the desired device for vibe not function. Make sure to set the default device in Oculus Home to only use a specific device.
    Just my .02 worth. I had this problem but it might not be what you are experiencing.
  2. Ukflyer99
    Ukflyer99 Wannabe Pilot Gold Contributor
    Maintenance Supervisor
    Wolverhampton
    193Coins
    Thanks for the information, bit busy at the moment so no play. Will let you know the outcome.
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,017Coins
    Be careful with Oculus ! You do not have to play audio from non VR app in headset !!
  4. Ukflyer99
    Wolverhampton
    193Coins
    Thanks for all your help, will get to it next weekend, all being well. Work gets in the way!
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    It's strange, when I start the game, the vibration starts alone, and in a random way, it does not seem to me according to what we are seeing on the screen! Likewise, when the car stops, that vibration continues ... was not it to stop too? I would like to read about other people's experience here, saying what they think, or if this is a problem that just happens to me.
  6. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Its correct to vibrate when the car has stopped (at idle) if you have rpm enabled if you rev the car the vibration sould then reduce the further up the rev scale you go;)
  7. paulopsx2
    brasil
    647Coins
    Its a roller coaster car... dont have "rpm".
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Lol i see, my fault for assuming you were talking about a race car :grin
    Ive always called a roller coaster car a cart :cheers
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @paulopsx2 anyway if you can find which Vibe is vibrating when it shouldn’t you should be able to tune it in on the Game Vibe tuning centre you might have to adjust the min value
    To find which is vibrating you can enable and disable each Vibe independently within the main Game Vibe window by clicking the speaker icon next to each Vibe hope this helps
  10. Historiker
    9,205Coins
    Try increasing the low setting in vibe tuning screen. This will remove input when the car is at rest.
  11. riton
    riton Active Member
    1,006Coins
    Hello, I still have this problem, is there a solution?
    thank you :)
  12. yobuddy
    51,518Coins
    @riton,
    For now try this buddy,
  13. riton
    riton Active Member
    1,006Coins
    ok , I will test this solution , thanks . ;)
  14. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    It worked for me. It is because in France we do not use the same separator for csv Which is used by gamevibe
  15. yobuddy
    51,518Coins
    Not sure yet.
    I took the coma and period into account when I wrote it.
    And a test yesterday left it working with coma as the separator?
    So I'm just not sure yet.
  16. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    No problems here
    with that:
    "." as decimal separator and "," as list separator
    Hope it helps
  17. yobuddy
    51,518Coins
    @vthinsel,
    Is that a coma or a period in the pic?
    Did you try it with both options?
    Thanks buddy,
  18. riton
    riton Active Member
    1,006Coins
    I will try this setting ;)
  19. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    coma as list separator, point as decimal separator
    before I had : coma as decimal separator and semi colum (;) as list separator and this generated popups.
  20. yobuddy
    51,518Coins
    Why would the semicolon cause problems I wonder?
