Question Simtool Setting...
Discussion in 'Commercial Simulators and Peripherie' started by kjjcard, Mar 23, 2018.
  1. kjjcard
    kjjcard Member Gold Contributor
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    Hello.
    I bought one SV-3TL and one SV-2 from NJMotion.
    It took time to assemble the whole product without a guide, but I did it anyway.
    But I do not know how to connect Simtool.
    I asked him, but he does not come back.
    What should I do?
    153,691Coins
    @RaceRay has a NJMotion rig so should be able to advise as to Interface Settings in SimTools.
  3. RaceRay
    Hamburg, Germany
    23,884Coins
    Hi @kjjcard
    these are my Game Engine Interface Settings:
    @NjMotion Can you make sure that he get the needed informations?
    Cheers
  4. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    We are in contact by mail. Send you the assembly pdf and the configuration. Your boss is the one who has been in contact with me, so he did not know anything about me.
    Thanks @noorbeast and @RaceRay
  5. kjjcard
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    He is kindly helping me.
    The part that did not work was solved.
    I would be happy if only the odd part of the current value is resolved!.
    The motion platform is great enough to cope with the time lag with him (about 8 hours).
    Thank you very much for your help.
  6. Hien N.
    Hien N. New Member
    40Coins
    2DOF, 3DOF
    I have the same problem,
    1. Computer recognised the COM3 connected via USB, the Rig auto moved to center the first time I connect it to to the powersources
    2. IP Setting was the same between Simtool Game Engine and Simtool Game Manager (I edited it)
    3. I have set the Axis Assignment in the GE with 3 Axis 1a, 2a and 3a
    4. I have set the Interface via Serial and exactly the same the image above.
    5. I CAN NOT test the output.
    Can I anyone help?
    153,691Coins
    You need to set Output Bit Range to 10.
    Parity to None.
    You should not need to edit the IP.
    As an aside LFS needs to be run before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  8. Hien N.
    Hien N. New Member
    40Coins
    2DOF, 3DOF
    153,691Coins
    Parity should be set to None.
    Output Testing should work as expected before messing with any game.
