UDP Messaging - Simulator
Discussion in 'Commercial Simulators and Peripherie' started by PaulMac000, Mar 29, 2018.
  1. PaulMac000
    PaulMac000 Member
    26Coins
    Motion platform
    Hello there,
    Hope someone might be able to point me in the right direction! Xsimulator helped me learn motion control for big robots which I turned into a company (www.see-it.tech).
    However, I've been pulled into a mini project to work on a motion simulator and have intercepted the UDP messages from the computer to the robot controllers.
    The simulator has two motors. One to turn left/right and one up/down.
    I can see UDP messages going from the computer to the robot controller via Wireshark. As example they seem to have a header and a footer. Then it seems to encode a value in binary that I've seen a top value of ~10,000. As example:
    00000000000000
    00000001100010
    00000110001010
    00001101110111
    000011000101001
    0000100110011110
    0001001011010000
    0001100010001011
    0001111100000101
    0010011000100110
    The data seems to be repeated 6 times every UDP message which seems a bit unusual...
    Can anybody point me in the right direction for material on how to understand the protocall?
    Additionally I can only seem to see one data stream when I should be seeing two. Any pointers??
    Thank you!
  2. SeatTime
  3. PaulMac000
    PaulMac000 Member
    26Coins
    Motion platform
    DIY? As in it should be moved into a DIY section?
    I've gone through the UDP code a few times and will experiment with it next week, I'm just wondering if anyone has any tips in the interim.
    153,890Coins
    +11,154 / 57 / -2
    @SeatTime means is your work in relation to a commercial or DIY simulator, as it sounds like the former and if so the thread belongs n the commercial thread section.
  5. value1
    14,240Coins
    Please read the documentation about SimTools first. There is no need to intercept any UDP stream.
    You can send the data from SimTools to a controller (SMC, ARD, JRK, whatever) without the need of reading with Wireshark.
    If your controller is not supported, you can even build a proper interface yourself.
  6. PaulMac000
    PaulMac000 Member
    26Coins
    Motion platform
    Excellent, thank you so much for the pointer. This was exactly what I was looking for. Much appreciated :)
    Apologies Noorbeast for the double post and wrong group. Will learn from my mistakes :)
