Haraguchi's DIY 2DOF cockpit project
Discussion in 'DIY Motion Simulator Projects' started by Haraguchi, Dec 13, 2017.
  1. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    I'm going to remove the side sticker from Playseat:
    And maked an art.
    I'll print on vinyl and put it in place:
    Tomorrow as soon as I get ready the sticker I 'l mount the simulator and put new photos!
  2. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    After disassembling and reassembling everything, I ran a test running LFS and it worked fine!
    Tomorrow the sticker is ready and I am ready to be tested.
    One more video:
  3. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Today came the 2nd source (PSU)
    Now each engine has its independent source PSU)
    Before:
    After:
  4. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    News !
    I put the sticker on, put it all together, now 99% done!
    I have a problem, I think with the engines, because after some time they lose communication ...
    With my daughter (it's about 32 kg) the simulator operates normally. when it is my turn (72Kg) the engines stops a short time ago ...
    I'll search more to see what the problem might be.
    Probably overload on the engines as they are only 100W.
    Novidades !
    Coloquei o adesivo, montei tudo, agora 99% concluído !
    Estou com um problema, acho que com os motores, pois após algum tempo ele perdem a comunicação...
    Com minha filha (tem uns 32Kg) o simulador opera normalmente. Quando é minha vez (72Kg) os motores param apos um curto período de tempo...
    Vou pesquisar mais para ver o que pode ser o problema. Provavelmente sobrecarga nos motores, pois eles são de apenas 100W.
    Photos:
    153,697Coins
    Have you tried a shorter CTC hole on the levers?
    And did you balance the rig with yourself siting on it, along with all peripherals?
  6. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Yes, I think I did it right.
    Would you have some place in the simtools to configure the power of the motors? Something like "full power"?
    153,697Coins
    No, SimTools does not do that, rather it is handled on the motor driver side.
  8. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Okay, thanks for the tips!
    Tomorrow I'll try to do what you suggested, I'll start for a shorter CTC hole.
    Thank you again !!
  9. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    News!
    I installed it on the CTC as close as possible to the motor shaft.
    Now it's all right !!
    I made some changes to improve the reliability because I noticed that the CTC already showed some signs of wear.
    ow it's closer to the middle of the shaft.
    Novidades!
    Instalei no CTC o mais próximo possível do eixo do motor.
    Agora sim, está tudo certo !!
    Fiz umas mudanças para melhorar a confiabilidade pois notei que o CTC já apresentou alguns sinais de desgaste. Agora ele está mais próximo do meio do eixo.
    Before: Note the simple actuators installed (left and right):
    After: (I modified to improve the actuators)
  10. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Before today's modifications I had made a video with my daughter driving the LFS:
    I saw that the axles were inverted, that is when the rear brake was lowered, where the right thing was to get up.
    Today has already been corrected, it is still missing the video.
    Antes das modificações de hoje havia feito um video com minha filha dirigindo o LFS.
    Vi que os eixos estavam invertidos, ou seja quando freiava a traseira abaixava, onde o certo era levantar.
    Hoje já foi corrigido, falta fazer o video.
  11. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Yes you need to invert your surge in simtools ,,,, Rig looks cool ,,,nice job :thumbs
  12. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Hello all well ?
    Thanks for the tip, I already made the corrections in Simtools and now everything is alright!
    I will post a new video soon!
  13. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Today I made (more) some modifications because the trigger was very long and was getting warped.
    Instead of passing under the cockpit frame I punched a hole through the profile and passed the trigger there.
    Let's see if with this modification the simulator is good.
    Hoje fiz (mais) lgumas modificações pois o acionador estava muito longo e estava ficando empenado.
    Ao invés de passar por baixo do quadro do cockpit fiz um furo por dentro do perfil e passei o acionador por lá.
    Vamos ver se com esta modificação o simulador fique bom.
    Before:
    After:
  14. piloulou
    piloulou New Member
    103Coins
    Bonjour
    je suis très intéresse par l'arbre et se système de montage
    ou avez vous l'arbre et un prix Commandez quel
    merci
  15. Francisco Junior
    Francisco Junior Member
    Curitiba - Brasil
    275Coins
    Você poderia postar fotos da configuração do teu SMC3Utils e do SimToolsGameEngine ?
    Could you post photos of the configuration of your SMC3Utils and SimToolsGameEngine?
  16. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
  17. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Opa tudo bem ?
    Sim segue a tela dos eixos e a da interface: O simulador não está conectado ao PC, assim que eu conectar posto aqui ok.
    HI, how are you?
    It follows the screen of the axes and the interface: The simulator is not connected to the PC, so I connect post here ok.
  18. piloulou
    piloulou New Member
    103Coins
    Bonjour Haraguchi
    merci beaucoup pour le lien de l'axe
    est que vous savez si il envoi dans le monde entier et plus particulièrement pour la France
    merci beaucoup
    votre simulateur est fantastique tres bon travail
  19. Francisco Junior
    Curitiba - Brasil
    275Coins
    Thanks !!!
  20. Haraguchi
    Haraguchi Member
    Gas rig operator
    Brasil
    120Coins
    Ok, the smc3 print:
