Resolved pb gtr2 no data sent
Discussion in 'SimTools DIY Version' started by Oms, Apr 3, 2018.
  1. Oms
    Oms known as "Doc6dof"
    France Colomiers
    - 173Coins
    DC motor, AC motor, Arduino, Motion platform
    Hello all, pb wit GTR2, GameEngine do not send data, COULD YOU HELP ME... THANK YOU IN ADVANCE...
    1) I am currently writing arduino code for my Xdof simulator ( https://www.xsimulator.net/community/threads/launching-of-my-6dof-low-cost-dynamic-simulator.11594/ )
    2) As the code is not finished, I check the data sent by GameEngine with an oscilloscope connected to the pin 0 of arduino board = RX (for information I synchronize the packets with specific 5 bytes: 000,FF,85,FF,00, following by the 2 16 bits axis).
    3) When I test the output with the GameEngine, I can see the 4 last bytes change (see the 2 oscilloscope photos, with surge at 0% then surge at 20%), so game engine configuration seems good (see the 3 screen shots: axis assignement, limiting, and interface setting).
    4) Then I have patched GameManager with GTR2 (GTR2_Plugin_2.0.0.2) doing a drag and drop in the PluginAdapter (no error),
    5) But when I play GTR2, GameEngine seems to send nothing (I can see it with the oscilloscope, the 2 axis surge and sway are stucked to 0% !!). Yet all other things seem OK ( "Game running", background blue, written in GameManager, and "Game On", background blue, written in GameEngine... (see the 2 screen shoots)
    What did I forget to configure ??
  2. yobuddy
    50,993Coins
    Please open the tuning center for Game Engine to see if you have any game data coming in.
  3. Oms
    France Colomiers
    - 173Coins
    thank you yobuddy, I try that this evening, but as all the applications gtr2, game manager, and game engine) run on the same pc, I need to stop the game to enter in the tuning center, so will I see data in this case ? Or do I have necessarily to use 2 pc connected by ethernet ?
    151,991Coins
    +11,061 / 56 / -2
    You don't need to stop the game while running the Tuning Center to observe if it is registering data, you will want to pause the game if you want to edit Tuning Center values.
  5. Oms
    France Colomiers
    - 173Coins
    ok thank Noorbeast I will pause the game and have a look to tuning center (i have never tried to open it until now)
  6. value1
    15,025Coins
    Have you checked this?
  7. Oms
    France Colomiers
    - 173Coins
    Hello Yobuddy and Noorbeast, I have opened the tunining center values -> no datas received, that confirms what I can see on my oscilloscope.
    N.B: I have tried with rFactor, and it is ok with this game, I can see the data received, in the center tuning and also on my oscilloscope.
    So far, do not understand this bug !!
  8. Oms
    France Colomiers
    - 173Coins
    Hello, thanks, I tried, but I did not see an answer to my problem...
  9. value1
    15,025Coins
    Well, do you have a line in the file
    …\Steam\SteamApps\common\GTR 2 - FIA GT Racing Game\UserData\<yourname>\<yourname>.PLR reading
    Write Shared Memory="1" // Write game data to shared memory area
  10. Oms
    France Colomiers
    - 173Coins
    I am using a dvd game
  11. Oms
    France Colomiers
    - 173Coins
    but I have found my name.plr, i will try
  12. value1
    15,025Coins
    Well, then check in the fiel C:\GTR2\UserData\<yourname>\<yourname>.PLR
  13. Oms
    France Colomiers
    - 173Coins
    You are a champion Nerd, THAT IS RUNNING !!!!! thanks thanks thanks
    2,21 GIGAWATT available !!!! GREAT SCOTT !!!
