DOF Reality platforms presets, profiles and tips
Discussion in 'Commercial Simulators and Peripherie' started by Mpmo, Dec 9, 2017.
  1. Radioproffi
    Lviv
    1,677Coins
    NoLimits2
  2. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    Does it work with no limit demo or do I have to buy the game? Also PC plug in vibrates crazy when the game starts and movement doesn’t match the game. What should I do? I use rift. I tried PC UDP, UDP FOR PC
  3. Radioproffi
    Lviv
    1,677Coins
    Did you change MAX/MIN value in Tuning Center?
  4. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    Thank you so much. I think I got it now.
  5. nilzilla
    nilzilla New Member
    US
    207Coins
    Sorry, just noticed that this is the thread to upload presets and profiles for DOFReality rigs.. I'll repost this here:
    As a recent H3 owner I'm still easing my way into SimTools. After some initial frustration with "why don't things just work.." I thought I share what I have learned with my preset values for OutRun 2006 (you can find the game free on google at the time of this writing). This game is best played with a wheel set to about 200 degrees of rotation (even if your wheel supports 900 or 1080 degrees you can change it in the control panel or in your wheel's setting app). Please note that the axis presets are similar to the Dirt4 presets included by DOFreality. I've also shortened the min/max values within the profile to give more of that arcade feel.
    outrun2006-DOFReality-axis_preset1of2.jpg outrun2006-DOFReality-axis_preset2of2.jpg outrun2006-DOFReality-profile.jpg
  6. Petrus_SM
    Petrus_SM New Member
    Hotel Night Manager
    Melbourne, Australia
    276Coins
    I tried this plugin and the tuning with my P3 but it doesn't move. Did I do anything wrong? Btw, I just tried with the No Limit 2 demo version.
    153,710Coins
  8. Petrus_SM
    Hotel Night Manager
    276Coins
  9. Petrus_SM
    Hotel Night Manager
    276Coins
    For some reasons, these axis assignments are not very accurate with my P3. It moves all over the place.
  10. Petrus_SM
    Hotel Night Manager
    276Coins
    My bad I forgot to save it. It actually works like a charm.
  11. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    ok i have for american truck simulator and need for speed, how do i upload them?
    153,710Coins
  13. Mpmo
    Mpmo Member
    1,289Coins
    153,710Coins
    You can create a Axis Assignment preset using the Preset button located in Axis Assignments.
    You can then find the saved preset in: C:\Users\Your_User_Name\AppData\Local\SimTools\GameEngine\AxisAssignmentsPresets\Generic2DStandard_Presets
    Zip the preset and then upload it.
    People can then unzip it and place it in the same folder, then access it using the Preset button to load the settings for a specific game and then save the settings for that game.
  15. Mpmo
    Mpmo Member
    1,289Coins
    American truck simulator, need for speed most wanted and rivals:
  16. Petrus_SM
    Hotel Night Manager
    276Coins
    Can anyone share their presets/tuning for Elite Dangerous?
  17. nilzilla
    nilzilla New Member
    US
    207Coins
    ED is still not every playable. The issue is with the current plugin/patch it seems to read joystick/KB input values and small and quick joystick movements causes a whiplash effect on the motion rig. I'm including the axis setting I've been using to for ED, I've since given up on trying to tweak it. Hopefully you'll have better luck than I did.
  18. nilzilla
    nilzilla New Member
    US
    207Coins
    Adding my presets for DCS, please note that this is using standard axis type for the extra filter options. I've found it to be needed for some of the propeller planes when they are on/close to the ground as their shaking "effect" causes unwanted wear on the motion rig. Also, try to avoid doing barrel rolls as it snaps the motion axis to the other side... Also as a side note, from experimentation I'm choosing the Sway output as the Yaw axis. I've found it to be a better representation of that motion axis from the available range out outputs.
  19. nilzilla
    nilzilla New Member
    US
    207Coins
    To clarify, I've added 100% smoothing to Sway (Axis-3 of DOF1) as the TF-51D plane in DCS will shake the 3rd DOF motor on the DOFreality H3/P3 rig when its on the ground. For roll (axis 1 and 2), I've also added 5% smoothing for good measure, but really haven't felt much difference there.
  20. Jeffery Ford
    Jeffery Ford www.youtube.com/FordEntertainmentGroupFEG
    Texas
    268Coins
    are the iracing settings in this thread still current for iracing as it is now? Not sure how long ago poster posted the information.
