Simtools motion question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by STEPHANIE, Apr 13, 2018.
  1. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    Bonjour, j'ai téléchargé la dernière version de SIMTOOLS 2, mon simulateur pour 4 moteurs (2 moteurs de chaque côté), de chaque côté de mon simulateur, il y a 1 sabertooh et un ARDUINO, par la suite istallation de SILMTOOLS, I have only 2 engines which work on 4?
  2. yobuddy
    51,006Coins
    What's that now?
    Please provide a English translation if you would.
    Maybe you need another Arduino setup?
  3. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    Here is a photo of one of side of my simulat simulateur cote droit.jpg Here is a photo of one of side of my simulator, I use 2 arduino, one on each side it is can be the problem there, I saw that some use an arduino microcomputing...
  4. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    And he(it) possible to use SIMTOOLS 2 with 2 arduino?
  5. yobuddy
    51,006Coins
    I'm not sure what you are having problems with?
    Yes, you could use up to 6 if needed.
  6. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    this picture of my simulator :
    1,2,3,4 = motor
    port com 4 =arduino 1
    port com 3= arduino 2
    MOTORS GREEN = PERFECT MOVE WITH SIMTOOLS 2
    MOTORS RED = Dont move whit SIMTOOLS 2
  7. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    With SIMTOOLS 1.3 everything worked perfectly.
    Nevertheless SIMTOOLS 2 re-knows 2 well cards(maps) arduino, but runs only the only one engines on 2?
    152,021Coins
    +11,061 / 56 / -2
    Are you using the SMC3 code or something else on the Arduinos and do all the motors respond properly on the hardware side.
    If so please post pictures of all of your SimTools settings.
  9. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  10. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  11. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  12. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  13. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  14. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  15. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
  16. noorbeast
    152,021Coins
    +11,061 / 56 / -2
    @STEPHANIE for SimTools 2 your Interface Settings should be like this: XL<Axis1a>CXR<Axis2a>C
    @Pit or @RaceRay can we please pull @STEPHANIE's configuration related posts out into their own thread.
  17. Historiker
    9,208Coins
    Done
  18. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    Hello, yes of course
  19. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    Incredible!!! THAT walks(works)!!! XL<Axis1a>CXR<Axis2a>C
    I thus filled(performed):
    Interface 1: XL<Axis1a>CXR<Axis2a>C
    Interface 2: XL<Axis2a>CXR<Axis2a>C
    Interface 3: XL<Axis3a>CXR<Axis2a>C
    Interface 4: XL<Axis4a>CXR<Axis2a>C
    You are the best !
    On the other hand I do not arrive has to change the sense(direction) of the engine 4 ( axis4a ) in axis assignements, I shot well "dir" but it does not walk(work)...
    152,021Coins
    +11,061 / 56 / -2
