DiRT Rally Plugin [Deleted]
Discussion in 'SimTools Plugins' started by llluis, Jan 24, 2018.
Thread Status:
Not open for further replies.
  1. Mu-KwangKim
    South, Korea
    - 689Coins
    Surge and sway do not come out normally.
    I remember it in the past ... I remember it was a game problem.
    Is it impossible to solve?
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    I, try to load default profile and click [save] before editing real profile values!
  3. Mu-KwangKim
    South, Korea
    - 689Coins
    The same is true with that method.
    In rally cross, it is so so...
    Hill Climb keeps going back to 0
    In Rally, it is always 0
    Other figures are normal, but only surge and sway problem.
  4. Mu-KwangKim
    South, Korea
    - 689Coins
    After looking through past data, I found that there was a problem only in window mode.
    When I tested to full screen, I noticed that the numerical values were displayed normally.
    The same thing can be done with a full screen in windowed mode.
  5. llluis
    Quebec
    1,632Coins
    I tried to debug like crazy this one and came to the conclusion it's something with the game, nothing I can do on plugin side.
  6. Mu-KwangKim
    South, Korea
    - 689Coins
    Oh ... you really suffered.
    As a result of checking several systems...
    It's random. :<
    Anyway, one of the three must be.
    Window mode or Full Screen mode or Window full screen mode :)
    (codemaster~~~~~~~~~~~~~~~~~~~)
  7. 17Nico17
    17Nico17 New Member
    Royan
    172Coins
    Hi everybody !
    If this question is still open i know why the game has some problems with Sway and Surge.
    It is not a windowed problem or at least it is not the only reason.
    I had a look at the graphic options such as tree details, watter details, car details, road details etc.... and if you put some to low or very low or deactivated, you have the problem with simtools then.
    I do not know which one is the cause but I had everything at minimum value (for my laptop) and I try to increase some if them to try and it worked perfectly after that.
    I think that the fact to decrease the capacities if the game can affect the data themselves.
    That is all for me. Enjoy
  8. jinho
    jinho New Member Gold Contributor
    - 627Coins
    thank u!!! :)
  9. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Im having the problem of sway and surge drop to zero when the car starts moving.. i read all the post, and i cant find a solution.., is there any solution?
    Before my new fresh install, everything was working well, as always..
    I tried this plugin and the other one with no luck
    Thanks in advance!
  10. yobuddy
    51,526Coins
    @MorciXL,
    Change the resolution and then change it back.
    Make sure your in full screen mode.
    Take care,
  11. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    I dont understand.. change the resolution to what? Im using 3840x1080 on Dirt Rally using Samsung C49HG90 momitor.
    Change to other resolution, and take back to 3840x1080?
    Thanks!
  12. yobuddy
    51,526Coins
  13. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Ohh, thank you! Will try later, thank you so much for your help.
    EDIT: Tried with no luck.. Sway and surge is at 0 when i start driving the car.. :(
  14. yobuddy
    51,526Coins
  15. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    The plugin works very well for me, thanks for that, but I have a problem, I use a Jet seat for the vibration that works with simshaker and the plugin cancels this, do you know if there is a way to make both things work?
  16. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Use this:
    http://www.eksimracing.com/blog-post/sim-racing-proxy-server-universal-udp-forwarder-solution/
    Just enter the 20777 port in the hardwareinfo.xml (ist in documents/mygames/dirtrally folder and add the simtools port and the simshaker port in the app.
    More info:
    https://www.xsimulator.net/community/faq/codemasters-use-simdash-and-simtools-simultaneously.143/
  17. polybasss
    Burgos Spain
    155Coins
  18. zevsss
    zevsss New Member
    Russia, Alikovo
    82Coins
    DiRT Rally plugin does not work in the steam version
    153,764Coins
    +11,149 / 57 / -2
    The plugin is built against the Steam version.
    Have you tried known solutions, such as using English Local language settings: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    On Codemaster games the patch path is different for 32 and 64 bit computers: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Does your rig respond correctly in Output Testing?
  20. ilbiga
    Network Engineer
    103Coins
    I @zevsss
    I regularly use the plugin with the Steam version.
    I think the problem is another one.
    Ciao
Thread Status:
