  1. Claudemir
    23Coins
  2. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Do you have a possibility to measure the A, or watts? But i think they will do it. I can't read the stickers. But antother thing... do you plan do use this Fantire?
    I believe, you will have more satisfaction with two of them: "Seaflo Blower 4" (12V)
    They have 270CFM. Cheap (27€), easy to mount and simply awesome!
  3. Claudemir
    23Coins
    [QUOTE = "Bastiuscha, postagem: 154768, membro: 25016"] Você tem uma possibilidade de medir o A watts? Mas acho que eles farão isso. Não consigo ler os adesivos. Mas outra coisa ... você planeja usando esse Fantire?
    Eles: "Seaflo Blower 4" (12V)
    Eles têm 270CFM. Barato (27 €), fácil de montar e simplesmente fantástico! [/ QUOTE]
    I finally managed to find 2 Seaflo Brawer. I also got the MMs. I'll wait to get started building
  4. Bastiuscha
    750Coins
    MM's? You only need one of them...but it's not bad, to have one as backup. ;D But great to hear!
  5. KevinSetz
    KevinSetz New Member
    Nederland
    131Coins
    Do i need a license for setup this fans? i have downloaded simdash but nothings work? can anybody help me?
    152,553Coins
    +11,087 / 56 / -2
    Yes a SimTools Pro license is required, see here for details: https://simtools.us/license/
  7. KevinSetz
    Nederland
    131Coins
    is there a way that i can test it for 2 days? i use it only for my wind sim and if in not working well then i have a license of 70 bucks.. :( that i cant refund i think.
    152,553Coins
    +11,087 / 56 / -2
    No, there is no testing access for SimTools companion apps, only SimTools itself, though there are plenty of member wind simulation project examples to show it working.
  9. Bastiuscha
    750Coins
    If your construction is correct, it will working well. You only have to check, do your plugin support wind simulation. I know, the pro licence only for wind sim, is not cheap. But if you use it one time, you never want to relinquish. :) And maybe in future, you have the possibility to use gamevib. For a good "wind" i recommend strongly, to use a seaflow or somthink like this. (I showed a few post's before)
  10. imagebuff
    imagebuff New Member
    Tomball TX
    269Coins
    Woohoo!! I got simtools + the wind simulator hardware working late last night. The speed of the two seaflo fans varies with the car speed.. perfect! Well not exactly perfect as my fans are turning in the wrong direction. The DC polarity is obviously backwards from the MM to the fans.
    Now I know I can desolder and reverse the polarity BUT is there a way to swap the fan output polarity in the arduino sketch? It would be much easier!
  11. KevinSetz
    Nederland
    131Coins
    Try with SimHub they have wind simulator to, works with motorshield now, maybe you got with that no problem.
  12. imagebuff
    Tomball TX
    269Coins
    Oh my.. I bought SimTools just for this purpose. SimHub works with MM now you say?
  13. Zed
    USA
    5,845Coins
    The way the H-bridge works you can swap the polarity of the output just with a bit flip in software I believe. If you aren’t handy with programming to find what in the code to change to change direction, it may be easier to just swap wires. Depending on your setup, it may even be more convenient to cut the wires and the wire nut them back together if you have to thread them through a frame or something.
    Welcome to the passing wind society... :thumbs
  14. imagebuff
    Tomball TX
    269Coins
    @SilentChill
    Thanks! I've got no problem modifying the code or handling the soldering as I put it all together. I'm pretty sure some manipulation of the variable declarations below is in order.. just not sure what.
    int inApin[2] = {7, 4}; // INA: Clockwise input
    int inBpin[2] = {8, 9}; // INB: Counter-clockwise input
    int pwmpin[2] = {5, 6}; // PWM input
    int cspin[2] = {2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13;
    Chris
  15. imagebuff
    Tomball TX
    269Coins
    Wind sim is now fully functional. Can't live without it now!
  16. Bastiuscha
    750Coins
    Look's nice! What is the black box for? behind the fan's...
  17. imagebuff
    Tomball TX
    269Coins
    Thanks! The black box you see is the cowling for the three iNuke rack mounted amps for the simvibe system
  18. Bastiuscha
    750Coins
    ahhh nice! Very good. I'm so sad, i can't use gamevib. With vibs, my motion canceling (for VR) don't work correct. :(
  19. imagebuff
    Tomball TX
    269Coins
    You can't isolate the spot from vibes?
  20. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    Thank you very much for your job and your participation :thumbs Very cool , thanks .. :thumbs
    It's very fun ! This is my new setup .
