My 2dof Bumpers
Discussion in 'DIY Motion Simulator Projects' started by titomaky, Apr 16, 2018.
  1. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    I will try to document my 2dof manufacturing project by modifying my home cabin to insert the wipers and electronics to turn it into a motion simulator. My goal is to be functional, quiet and occupy the minimum space.
    Voy a tratar de documentar mi proyecto de fabricación 2dof modificando mi cabina casa para insertar los limpiaparabrisas y la electrónica para convertirlo en un simulador de movimiento. Mi objetivo es ser funcional, tranquilo y ocupar el mínimo espacio.
  2. titomaky
    181Coins
    Motion platform
    152,373Coins
    +11,076 / 56 / -2
    Thanks so much for sharing your project.
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
  4. titomaky
    181Coins
    Motion platform
    For my project I will use 24v motors
    Para mi proyecto voy a utilizar motores de 24
    These original engines are prepared to work at various speeds, so we will proceed to disassemble and prepare our engine to work at the fastest speed. We are also going to isolate the mass of the chassis, since this is important so as not to derive voltage to our Monster Moto Shield or IBT plate which would end up burning.
    We will also eliminate the remaining wiring and leave only two cables for positive and negative.
    Estos motores originales estan preparados para funcionar a varias velocidades, por lo cual procederemos a desmontar y preparar nuestro motor para que trabaje a la velocidad mas rapida. Tambien vamos a aislar la masa del chasis, ya que esto es importante para no derivar voltaje a nuestra placa Monster Moto Shield o IBT la cual se terminaria quemando.
    Tambien vamos a eliminar el cableado sobrante y dejar solo dos cables para positivo y negativo.
    [​IMG][​IMG]
    Once the lid is removed we will cancel the cables used for the windshield wiper motor maneuver since we only need the two power cables, we also clean the temples and leave nice.
    Una vez desmontada la tapa vamos a anular los cables usados para la maniobra del motor de limpiaparabrisas ya que nosotros solo necesitamos los dos cables de la alimentacion, de paso tambien limpiamos las patillas y dejamos bonito
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    Here we can observe the brushes. In this particular engine we find three brushes, one is the negative and is usually connected to the engine chassis, this is the one that we will have to isolate to avoid problems in our monster moto shield.
    Aquí podemos observar las escobillas. En este motor en concreto nos encontramos con tres escobillas, una es el negativo y generalmente es la que esta conectada al chasis del motor, esta es la que deveremos aislar para evitar problemas en nuestra monster moto shield.
    [​IMG][​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG][​IMG]
    [​IMG] [​IMG]
    I will continue editing this post......
    Seguire editando este post.......
