DANIEL'S 2DOF SCN5+12V WORM GEAR MOTOR TL
Discussion in 'DIY Motion Simulator Projects' started by Danny255, Jan 17, 2017.
  1. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Thank you ilbiga :)
    For welding,i have friend in my job,so he did it for a bottle of vodka :D
    And other work(bowing sheet metal,drilling,mechanical part of shifter and handbrake) by me.We have a lot of machines in job,so there is no problem to do things like this :)
  2. Nick Moxley
    17,056Coins
    Who made you the Axles for the motors ?
    ps we cant click on any of your pics to see them full size. :(
  3. Danny255
    Danny255 Member
    Pardubice
    215Coins
    sorry that pictures were very small i will make new post :)
    Axles was made by 3 people,Me with mill(square),my friend on lathe(diameter+thread) and driller(hole)
  4. Danny255
    Danny255 Member
    Pardubice
    215Coins
    New post(sorry for previous)
    1)Made new holders for pgsaw motors
    2)Wired up buttonbox,combined with GI max gear indicator,it don't look proffesionaly,but it fullfils the purpose.For the control board,I'm using Leo bondar buo836,it's a great controller,which is compatible with any game i have played yet :),so I can recommend that.
    waterpoof connectors are so great!!especialy for beginners as me,if you don't want soldering,this is the best choice.But they are rated for smaller current,so be carrefull for what are you using them :)They are very cheap on Ebay and sold in big packs(China).
    3)
    Moded trustmaster t500 wheel with adapter which i bought here:Fitting really good
    https://www.ebay.com/itm/Thrustmast...var=562459028577&_trksid=p2057872.m2749.l2649
    photos:
  5. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Oh i didn't know that :/..i just could not open them,so i thought they are just small.
    Next time i will know :)
  6. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi, really great work, congrats !
    With regards to your motors: Have you manually removed the inside gear of the motor and turn it, so that you have a left and a right motor ?
    If yes, was it a simple action ?
    Thanks,
    Arazok
  7. Nick Moxley
    17,056Coins
    Yes flipping the gear inside is easy peezy, Pop the screws out and flip. IF the gear sticks to one side, take a screw driver handle and tap on the output shaft to get it out. Some of the Case castings and the bearings are a tight fit. Some are loose.
  8. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Yes!How Nick says it's very easy.You do not have to worry.
    Just be care to srews from cover.On my motors,they were too tightened,so i had problems to open them,because i rewound head of screws(there is a cross).So press the screwdriver really perpendicular.
  9. Danny255
    Danny255 Member
    Pardubice
    215Coins
    And if you can,use gloves,there is very sticky vaseline,which is baddly droping out of your hands ;)
  10. Arazok
    Arazok Member
    Computer scientist
    783Coins
    thanks guys!
  11. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Hi guys,i want to ask you about motors:
    Yestreday i have tried to connect construction with levers,and motors just moved under the weight strain(without any current),is that normal?I am using pgsaw motors.I didn't know,when this is possible.
    In this case,I can set min and max of pot by hand,is that right?
    With wiper motors,it was not possible.
    152,009Coins
    +11,061 / 56 / -2
    The 25:1s can be back drive by hand and that is normal. The 50:1s can be back driven under load once they have been used for a while, again that is normal.
    Yes you can set the Min/Max by hand.
  13. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Thank you for info noorbeast :)
  14. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi Danny255 again,
    How do you make the great shaft for the pgsaw motors ?
    Or have you bought them ?
    Thanks,
    Arazok
  15. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Hi Arazok,Shafts has been made in my job by machines,it took a lot of work.But everybody has to contribute shaft for themselfs.Every sim is little bit different from each other.
    Try to look up in forum,for more and more tips,and you will find best and easy solution for you :)
    Problem is,when the shaft diameter have to be accurate to sit inside bearing.If you dont have possibility to tell some friend with Mill,Lathe machine..you can design it in some construction program and go to produce in some bussines for money.
  16. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Ok, thanks.
    But as I ordered also the pgsaw motors: Do you have the measurements of your shafts ?
    I can adapt them for my individual rig, but the fitting into the pgsaw motors should be the same :)
  17. Danny255
    Danny255 Member
    Pardubice
    215Coins
    You're welcome :)...Now I am at work,and dont remember dimensions.I will measure it at home and write it to you.But you have to consider one thing,that i have square on maded shaft,as well on lever instead of hole.(I made square,because i want to prevent lever from overspin under preasure).I will post pics of levers,and you will know,what i mean.I want to say,that your shaft have to be different,if you want to attach lever by hole.
    Tommorow,or at the weekend,i will post pics for better understanding :)
  18. Arazok
    Arazok Member
    Computer scientist
    783Coins
    great, much appreciated :)
  19. Danny255
    Danny255 Member
    Pardubice
    215Coins
    Hi Arazok,sorry for delay post,i was very busy.
    I have done some dimensions for you,and coming with explanition with that "square for lever"
    Dimensions of my axles (I hope you can read it,I am not ingenier,it could be confusing :D :D)
    And there is square what i thought...9mmx9mm,same is on axis.So you can do this..or do classic hole and diameter,it depends on you
    How it looks in assembly
    [​IMG] [​IMG] [​IMG]
  20. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi Danny255,
    no problem with the delay, my pgsaw are not delivered yet.
    Thanks for sharing, but unfortunately the images cannot be opened. An error occured.
    Any idea what is wrong ?
    cheers,
    Dirk
