News New higher Voltage / Amperage JRK's!!!
Discussion in 'Ready, set, go - Start your engines' started by Brett Horton, Apr 20, 2018.
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    • Informative Informative x 3
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    24v 27 amps is still a bit weak in comparison to what dimension engineering is offering. but its almost double the original. this should be a nice upgrade should someone decide to go this route. good find, especially with the 40% off.
  3. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    Is there a guide as to which G2 to buy ?
    My interest would be for a small wiper motor and separately for a rear traction loss actuator.
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    IMHO you will get better bang for your buck with a sabertooth 2x32.
  5. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    ¿Cuál es la diferencia entre popolu e IBT2?
  6. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Question for everyone, what do you recommend?
    I notice that the "Quantity Available" shows me that the 24v21 and the 24v13 are the most popular items.
    FYI: I have the 12v12.
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    My power supply output is 12V at 47 Amp Maximum with 575 Watts Maximum
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    do your motors support24volt?
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Yes! they actually can operate from 12v to 24v but I do not have 24v power supply
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    i am thinking to go with the 18v27 because of the Higher Amps... is that a good decision?
  12. Nick Moxley
    Yes Morton you want the 18v27
    and here's some info for the guys curious on the differences between the old and new, https://www.pololu.com/docs/0J73/1.2
    Ive got a pair coming for myself after a long discussion with support and sales, We'll see what there all about.
  13. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I got mine already here are some pictures next to the JRK 12v12 and the new JRK 18v27
  14. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Hi Guys,
    Can anyone confirm if these 18v27's still run at 12V but cope with the higher Amperage??
    The specs only state a MAX which makes me think 12V would work fine..?
  15. Archie
    Wollongong, NSW, AU
    3,797Coins
    Never mind. Should have Google'd first :)
    From Pololu site: This version offers a wide 6.5 V to 30 V operating range and can deliver continuous output currents up to 27 A without a heat sink.
  16. Nick Moxley
    AND if we do need to cool them , you cool from the bottom side mosfets. ;)
  17. Archie
    Wollongong, NSW, AU
    3,797Coins
    So tempted to get these and some new motors.
    My 50:1 worm drive gears have started to slip. I can be sat in my seat with the power off and moving in the seat will cause the motors to drop to the floor :( . Just likes the 25:1's do... In fairness, they have been hammered for the best part of two years! :)
  18. noorbeast
    152,971Coins
    +11,115 / 56 / -2
    I have mentioned a number of time that 50:1s can be back driven after they are broken in.
    So far 60:1s on my rig still can't be back driven even after years of use.
  19. Archie
    Wollongong, NSW, AU
    3,797Coins
    Yeah. Thinking 60:1's are the way to go.
    Apologies @noorbeast - Must have missed that post, it's good to know it's not a design flaw and more an expectation :)
    Anyway, as you were, I don't want to hijack this JRK thread with my musings... :D
  20. Archie
    Wollongong, NSW, AU
    3,797Coins
