  1. noorbeast
    152,977Coins
    +11,116 / 56 / -2
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
  2. Nellrolandmosselbay
    Nellrolandmosselbay New Member Gold Contributor
    South Africa
    87Coins
    Hi, can I use 2 of the DQ860MA Drivers instead of your "Monster Motor Board"? I have two Nema42 that I am going to use.
  3. Francisco Junior
    Francisco Junior Member
    Curitiba - Brasil
    275Coins
    Hello everyone
    I am building a 3 dof using mode2.
    I am using 3 IBT2 and 3 worm gears by PgSaw. (https://www.ebay.com/itm/GEAR-MOTOR...LL-FEED-150-160-rpm-25-1-ratio-/351066992384? hash = item51bd392f00)
    In the initial tests everything is working normally. Today when I complete the construction, one of my engines (board 2) began to turn only to one side.
    Turning right and left, it switches between slow and fast, but to the same side. With the other two engines I do not have this problem.
    I changed the order of the motors, and always what is on board 2 has this problem of turning only to one side. That is, the problem is not in the motor, but in the board.
    I've checked the wiring, but it's all correct.
    I tried to redo the settings in SMC3Utils but it remains the same.
    Is it possible that the board has been damaged?
    Any solution.
  4. Francisco Junior
    Curitiba - Brasil
    275Coins
    Complementing.
    I unplugged all the wires and tested this board with the 3 motors and the problem persisted.
    Is there any way to reset the ibt memory?
  5. SimplyPakistani
    SimplyPakistani New Member
    Pilot
    Multan
    155Coins
    Job well done and nicely elaborated @RufusDufus, will you please tell if simtools and smc3 can be used on a single pc without intermediate pc(to control sim motion via arduino), if yes then min requirements of the system to run game,simtools and smc3 utility software??
    Regards
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    Depending on specs one PC should work. Which game and what are the specs of your PC?
  7. SimplyPakistani
    Pilot
    Multan
    155Coins
    Thanks @bruce stephen for response, Dirt 4, RYZEN 5 1600, RX 580 8Gb, DDR4 16Gb 2400mhz
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    This pc should run everything without issue.
  9. SimplyPakistani
    Pilot
    Multan
    155Coins
    Gracias :)
  10. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    Thanks for the great software and firmware, with it I managed to move my big 80A 12v gearmotors, opel corsa b. everything worked right away even with xsim. here is the video of the first movement on the bench full of disorder
    Grazie per il grande software e firmware, con esso sono riuscito a gestire i miei motori da 80A 12v, elettrosterzi opel corsa b. ha funzionanto tutto subito anche con xsim. ecco il video del primo movimento sul banco pieno di disordine
    https://www.xsimulator.net/community/threads/my-wheel-plus-2dof-project.11796/#post-155393
  11. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
  12. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Another day another problem ;) Everything was fine with my seat and SMC gr8 software, but today... when I was turning it on seat center is broken. My chair is strong on the left side in the default position ;/ (I'm on v. 2.2.5). When I'm testing with SMC3 software everything is OK, but after Simtools is on everything is broke. My system is Win 10 ENG (with polish language installed). Nothing was changed on my system. I've heard that some win10 update was coming. Is it possible it is his fault? Could you help me wit this problem please?
  13. noorbeast
    152,977Coins
    +11,116 / 56 / -2
  14. gorzasty
    Poland, Wrocław
    1,060Coins
    Thank You @noorbeast ! As always You are the best with your advice ;) That was it. Changed the region settings and everything is ok. Why Simtools is so vulnerable with this settings...
    152,977Coins
    +11,116 / 56 / -2
    It could be that this is a Windows problem, not actually SimTools itself, and @yobuddy and others have not been able to pin a common cause down.
    If you would not mind can you please run a Belarc Advisor report, remove identifying product keys but PM the rest to @yobuddy for analysis: http://www.belarc.com/Programs/advisorinstaller.exe
  16. evolaco
    evolaco Member
    Spain
    694Coins
    using two arduinos how does the pot used to vary the scale work? Do you have to put two pot?
  17. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi, i have one problem with smc3 and MM: everything is working fine with simtools (demo), output test and the smc3 setup utility. Motor is moving in right direction.
    But: whenever the hallsensor is going below a specific value (i guess it is 255) the motor stops, even if there is no limit or clipping set (currently no rod mounted to motor). in the opposite direction everything is fine, goes up to 1000 (as set in code) but not in the down direction. and whenever it stops, i have to loosen the hallsensor, turn it above 255, tighten it, set motor to „on“ in the smc3 tool, and give it another try......
    any idea, what could be the problem ?
    cheers, Arazok
  18. Arazok
    Arazok Member
    Computer scientist
    783Coins
    ok, problem solved.
    There were old limits set inside the eeprom, which I haven‘t seen.
    Forgot to press „save image“ inside the smc3 tool when adapting the values.
  19. Gustavo Massaneiro
    Gustavo Massaneiro New Member
    Brazil
    80Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    @RufusDufus
    Awesome work!
    I'm starting my mini 6DOF prototype using your SMC3 software, but I'm changing some important things:
    1 - I'm using rotary encoder based on interrupts instead of pots (https://github.com/Billwilliams1952/KY-040-Encoder-Library---Arduino)
    2 - I'm using freeRTOS for Arduino, so I'm creating parallel tasks (https://github.com/feilipu/Arduino_FreeRTOS_Library), the minimum tick time is about 15ms, so I'll check the results using tasks
    3 - I removed everything related to motor 3, so the software will handle just 2 motors per Arduino. (SMC2)
    4 - Can you please provide the SMC3 Util source code? (I want to update the protocol and remove the motor 3 settings)
    As soon I have some result I post here, I'll also create a GitHub for the SMC2 project using freeRTOS.
    Thank you!
  20. sam poole
    sam poole Active Member
    midlands
    30Coins
    After windows update my arduino board have changed com ports had to set them again in simtools using 3 4 and 5 instead of 7
