Filters for G-seats
Discussion in 'DIY Motion Simulator Projects' started by SimPotato, Apr 27, 2018.
  1. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Is there any way to filter simtools to do the following:
    Filter only DOF3(sway) keeping DOF1(surge) And DOF2 (heave) unfiltered.
    Making Axis 1 to output only negative and Axis 2 to output only Positive??
    Lets say a take a left curve:
    I want the right flaps (Axis 2 Dof3) to rise
    and
    the left flaps (Axis 1 Dof 3) to remain flat and not to depress.
  2. MarkusB
    4,215Coins
    I don't know if you can achieve this via SimTools settings, but it is definitely possible with some adjustments of your Arduino code.
    Have a look at this code provided by @Spit40.
    If you only want the filter for sway and not for surge, you will have to do some more modifications on this code.
    For example, you could define separate axis for sway and surge, which are both triggering the same servos, but the one with the filter applied and the other without.
  3. early_m
    early_m Active Member
    Chelmsford
    839Coins
    I achieved this using @Spit40 's ard code. Not currently achievable through simtools.
  4. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Thanks, those codes are for servos, but I'm running 200w 12v dc motors on a 2x30 sabertooth with SMC3.
    I think the solution lies somewhere in the configuration on the simtools game engine.
  5. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    These two pictures will help visualize the challenge.... Untitled-1.jpg 1.jpg
  6. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    I think I have a solution in theory!
    The key relies in the plugin!
    You create a clone of " let's say the asseto corsa plugin" and you modify it.
    You make the Extra 3 telemetry a clone of the SWAY telemetry.
    Now you have two independent telemetry channels for Sway.
    Then you go into the Tuning center and set the game limits for your original Sway Max 10 and Min 0
    Then you set the limits for your Extra3(now your sway2) to Max 0 and Min -10.
    Does This Make any sense? or is it even possible?
  7. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Thanks to Value 1
    Here is AC plugin with
    Extra2 is +Sway and Extra3 is +Sway.
    Adjust the settings in TuningCentre first!
  8. yobuddy
    51,535Coins
    Hi Guys,
    We should be able to do this without modified plugins like this. :cheers
    First Game Engine needs to be in "Expert" mode, this gives us separate Min/Max files for both (a) and (b) Axis Assignments.
    Then setup you axis assignments like this.
    Notice this is the - (a) Axis Assignments.
    Notice this is the - (b) Axis Assignments.
    Then in Tuning Center, make sure both sets of Min/Max settings for (a) & (b) Axis assignments are the same, except for sway.
    For (a) Axis Assignment use a sway like this.
    And for (b) Axis Assignments use a sway like this.
    What you have essentially done here is turn off sway in one direction for each axis (the 0 turns them off in that direction.)
    Now all you have to do is change your interface output.
    Wherever you are using <Axis2a> Change it to <Axis2b>.
    With this example above, all game plugins should be usable without modification.
    If anything in the example needs more explaining, let me know!
    Take care, :thumbs
  9. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Yobuddy, You are the best! Thanks. I had the old Simtools w/out expert mo0de.. I'm getting the new one
  10. RacingMat
    21,082Coins
