DCS 2.5 Open Beta Now Out
Discussion in 'Digital Combat Simulators (DCS)' started by Zed, Jan 31, 2018.
  1. Zed
    USA
    5,845Coins
  2. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    the old plugin does not work for me in my 2dof, will there be a new plugin for this verdion 2.5?
  3. SeatTime
    Thanks for the heads up :thumbs - I fired it up for a quick look (automatically loaded from steam), but too busy to do much else at the moment.
  4. Arianus One
    empleado
    16Coins
    Does anyone know if a plugin is being made for dcs world 2.5 or 2.5.1 ??? Plugin of 1.5 works too bad on my simulator 2dof
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
    problem with steam is you cant use some of the modules. The ntta map doesnt work on steam. there may be others also.
  6. Arianus One
    empleado
    16Coins
    uhh, i doesnt have steam version, but that maybe cause problem to made plugin i imagine !! i bought my rig 2dof for this game mainly :(:(:(
  7. value1
    14,175Coins
    @Arianus One: Please be so kind to read the documentation of SimTools! Read it once, ready it twice, digest it and apply the things you learn there.
    Apparently none of the plugins don't work just for you and for everybody else they work. It must be something with your settings.
    It cannot be that all the plugins are broke, like you continously moan in various different threads!
    PS: The DCS plugin also works with DCS 2.5 in general.
  8. Arianus One
    empleado
    16Coins
    My apologies, plugin works on 1.5 but in my simulator i touch the profiles from the game engine and the tunning center I do not achieve that it is playable, the movements are very abrupt and make it unplayable, for more than I see the tutorials I can not do it, it is worse when touching it. In elite dangerous it worked so also of abrupt and I could not soften the movements or stop following the return of the lever to the center very annoying thing in my simulator and now finally it stop working with wow64.dll error. the only plugin that I can play and it works perfect without touching settings is the dirt rally, assetto corsa and pcars work but not as well as the dirt.
    I will read this as the last attempt https://www.xsimulator.net/simtools-game-engine/#Setting-up-your-Default-Axis
    i not mecatronic engineer i only a final consummer
    if not works i sell my simulator soon. i
  9. Arianus One
    empleado
    16Coins
    I bought a new joystick that would arrive in a week to see if that's the problem and the simu responds better with a new joystick (hotas x52) Again sorry by my comments,
    plugin are fine, but, for me it is complicated to make it work to the fly sims in my rig !
    thaks you very much
    greetings regards
