Tutorial How-to guide: Real car dashboard for racing games
Discussion in 'DIY peripherals' started by jjanu, May 10, 2018.
  1. jjanu
    jjanu LiveForSim Gold Contributor
    Multimedia
    Québec
    643Coins
    Hi All,
    This post will provide you with a complete procedure on how to use a real car dashboard with compatible racing games and a detailed list of the material to acquire. The main components include a Mazda 3 2005 instrument cluster, a TM1638 digital display, a Arduino Mega 2560 micro-controller, a SeeedStudio CAN-BUS shield and a 12 volt ATX power supply. The concept was presented in my earlier post in which I was studying how to port to Simtools my project that was initially programmed and configured for X-Sim many years ago. With the help of fellow members I successfully adapted the codes and commands in order to have a complete solution that can be implemented into Simtools. And I'm glad to share this resource with you.
    The attached document includes a step-by-step guide in PDF format with links and codes. You can also access the complete documentation on my OneDrive shared folder: https://1drv.ms/f/s!AtwKGzBk3VOohJdXo46y1V035DA0PQ
    The solution was tested with Assetto Corsa and Project Cars.
    152,367Coins
    +11,076 / 56 / -2
  3. jjanu
    Multimedia
    Québec
    643Coins
    Thanks noorbeast.
  4. Allan Soto
    Allan Soto New Member
    IT
    SA
    - 34Coins
    Hi, @jjanu thanks for your post, you inspired me!
    I can to use your arduino code in other Instrument Cluster?
    I am building a cockpit with Jaguar parts.
    I have the SimTools Professional license and a Jaguar Instrument Cluster ( S-Type 2005 ).
    I found the CAN(+) and CAN(-) pinout (JagRepair.com), but the Instrument Cluster don't work.
    Or this Instrument Cluster have a security system and I need a startup output.
    Thank you
  5. Johnixel
    Johnixel New Member
    23Coins
    Hey mate, your link is no longer working. Any chance you can update it for me? I am trying to get a 2016 Mazda 3 BN to work with my sim. Trying to figure out your wiring compared to mine but im getting close.
    152,367Coins
    +11,076 / 56 / -2
  7. Johnixel
    Johnixel New Member
    23Coins
    No worries. Ill wait for a response. Im chasing the code and the other files mentioned in the PDF.
    Thanks.
    152,367Coins
    +11,076 / 56 / -2
    Yep you will need to as that link is dead :(
  9. VintageCollector
    VintageCollector New Member
    11Coins
    Hi noorbeast,
    I still have the original files for this project I had saved in my google drive 2 years ago when I was building a cluster project. Though I ended up going with a BMW E46 I still kept this as a backup just in case of a scenario like this and if I wanted to try a Mazda cluster. I don’t know if it’s okay to post a link here since it isn’t my work. But let me know if anyone needs the file maybe I can PM them the link.
  10. damo2024
    damo2024 New Member
    - 22Coins
    Hi could i please grab this link as well I'm trying the exact same but am getting a lot of errors. Thank
