DIY 3DoF Simulator for Research
Discussion in 'DIY Motion Simulator Projects' started by Tao, Jan 4, 2018.
  1. Tao
    Tao New Member
    94Coins
    I'm building a 3Dof simulator for research (seriously :)). I guess the amplitude and tilt angle are probably larger than most gaming simulator. Amplitude is 6 in (12 in displacement). I've finished the mechanical designing part. Here are some figure showing the CAD model. Most parts are made of steel.
    Base:
    U-joint (better for large angle than a single ball joint):
    One thing I'm not fully confident is the crank:
    I'm not sure the connection between the crank and shaft is good for long term use. The motor I'd like to use is this.
    upload_2018-1-4_11-53-5.png Anyone have any idea regarding my crank?
    I'll update when I have more progress. Happy new year!
    It's been a long time...
    I have to modify my design a little bit and finally made some progress on the machine. Square tube has round corners. There is not enough room for me to mount the motors. I've made three motor bases.[​IMG][​IMG]
    I used angle aluminium to make the mounts of potentiometers.
    Two out of the six through holes in the motor shafts are off-centered. Luckily, I only made three cranks before noticing this.
    I think it's time for me to test motors. I brought two Sabertooth and one Arduino. Anybody know if I need to buy another Arduino to control three motors? This post (
    SMC3-SPS Sabertooth Packet Serial PID motor driver w/SoftStart
    ) only support two motors. I think Arduino is able to give 6 output channels which should be enough to control two Sabertooth. I do appreciate it for any direction!
    05.22
    Everything is wired up and ready for test. I have some problem. The movement of the motors is not smooth at all. Here is a video showing sudden movements when I Output Testing them in Simtool. I was dragging the slide from one end to the other end slowly.
    Does anyone have a idea what may cause/solve this problem?
  2. Gadget999
    12,132Coins
    looks good !
    what made you choose 3dof over 6dof
    when do you start building ?
  3. Tao
    Tao New Member
    94Coins
    Cost is one reason. And 6dof is actually not necessary for my project.
    I'm gonna order materials next week. Hopefully I can start the week after next week.
  4. Tao
    Tao New Member
    94Coins
    Just realized that I can modify my first post. LOL. See update in my first post.
    I have to modify my design a little bit and finally made some progress on the machine. Square tube has round corners. There is not enough room for me to mount the motors. I've made three motor bases. WeChat Image_20180513222825.jpg WeChat Image_20180513222835.jpg
  5. Gadget999
    12,132Coins
    i think the smc3 will support 3 motors if you use pwm channels
    however another arduino is cheap and will not add much cost to the project
    program the smc3 and get the test program working
  6. Tao
    Tao New Member
    94Coins
    Thanks! I found a code wrote by Wanegain which is good for up to 6 motors using only one Arduino. It works, suppose. At least my motors are moving. But I think they need some tuning as the movement is a not smooth at all.
