Showroom Mi/My Cockpit Simracing DIY Movimiento/Motion SCN5
Discussion in 'DIY Motion Simulator Projects' started by cover4x4, May 15, 2018.
  1. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    (Sorry, I use Google Translate Spanish-English ...) Hello, I have a Cockpit made of aluminum with which I play almost exclusively in Assetto Corsa and when I have time I run in SRS (Sim Racing System). I will shortly modify it to make the seat move along with two actuators SCN5 10-150mm and that I will show the progress. Currently I have this installed:
    - LG LED projector: 475 euros
    - DIY aluminum cockpit with "Motedis.de" material: 200 euros
    - Thrustmaster TS-XW Racer steering wheel: 600 euros
    - Logitech G27 pedals inverted with vibration: ??? euro
    - Change Logitech G27 modified for handbrake: ??? euro
    - Sequential Shifter manufactured by me in 3d printing: ??? euro
    - Shifter "H" of SHH modified with shorter lever, real knob and guided in aluminum: 115 euros
    - Bodyshakers with Simvibe license and amplifier: 300 euros
    - Backet fiber: 150 euros
    - Skullcandy Hesh 2 wireless headphones: 74 euros
    - Logitech keyboard wireless: 25 euros
    - Computer i5 6400/16 gbRam / Nvidia 1060 gtx 6 gb: 850 euros
    I have this material to assemble:
    - 2 actuators SCN5 10-150mm
    - Connection box 240x190x90mm
    - Power supply MeanWell RSP-320 24v 320w
    - Devantech USB RS485 converter- Ball joint
    - Other material varies- (I need to buy the aluminum for the extension of the Cockpit, shortly)
    (Perdón, uso traductor Google Español-Inglés...) Hola, tengo un Cockpit fabricado en aluminio con el que juego casi exclusivamente en Assetto Corsa y cuando tengo tiempo corro en SRS (Sim Racing System). En breve lo modificaré para hacer que el asiento tenga movimiento junto con dos actuadores SCN5 10-150mm y que iré enseñando los progresos. Actualmente tengo esto instalado:
    - Proyector led LG: 475 euros
    - Cockpit aluminio DIY con material de "Motedis.de": 200 euros
    - Volante Thrustmaster TS-XW Racer: 600 euros
    - Pedales Logitech G27 invertidos con vibración: ??? euros
    - Cambio Logitech G27 modificado para freno de mano: ??? euros
    - Cambio secuencial fabricado por mi en impresión 3d: ??? euros
    - Cambio H de SHH modificado con palanca más corta, pomo real y guiado en aluminio: 115 euros
    - Bodyshakers con licencia Simvibe y amplificador: 300 euros
    - Backet fibra: 150 euros
    - Auriculares Skullcandy Hesh 2 inhalámbricos: 74 euros
    - Teclado Logitech inhalámbrico: 25 euros
    - Ordenador i5 6400 / 16 gbRam / Nvidia 1060 gtx 6 gb: 850 euros
    20180515_184116.jpg 20180515_184013.jpg 20180515_184040.jpg 20180515_184137.jpg 20180515_183955.jpg
    Tengo este material para montar:
    - 2 actuadores SCN5 10-150mm
    - Caja de conexiones 240x190x90mm
    - Fuente alimentación MeanWell RSP-320 24v 320w
    - Conversor Devantech USB RS485
    - Rótula para asiento
    - Otro material vario
    - (Me falta comprar el aluminio para la ampliación del Cockpit, en breve)
  2. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Update with photos of the material I have to ride to do the motion.
    Actualizo con fotos del material que tengo para montar para hacer el motion.
    Actuators SCN5 10-150mm with modification of connectors keeping the originals.
    Motores SCN5 10-150mm con modificación de conectores manteniendo los originales.
    Here the Connection Box 240x190x90mm with holes for cooling, where an aluminum base goes with the MeanWell RSP-320 24v 320w power supply and the communication electronics.
    Aquí la Caja de Conexiones 240x190x90mm con agujeros para refrigerar, donde va una base de aluminio con la fuente de alimentación MeanWell RSP-320 24v 320w y la electrónica de comunicación.
    Support printed in 3d for Devantech USB RS485 converter, Diode 27v 1,3w and Resistance 2200 ohms of the ILK.
    Soporte impreso en 3d para conversor Devantech USB RS485, Diodo 27v 1,3w y Resistencia 2200 ohmios del ILK.
  3. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Today I have advanced a little more, I have prepared a steering wheel of an industrial vehicle without determining by welding two thick washers to be able to attach to the aluminum cockpit and that it will be placed under the fiberglass baquet so that it can move
    Hoy he avanzado un poco más, he preparado una rótula de dirección de un vehículo industrial sin determinar soldando dos aranderas gruesas para poder sujetar al cockpit de aluminio y que irá situada debajo del baquet de fibra para que se pueda mover.
  4. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    I'm moving forward after some problem with the SCN5 actuators (thread here) and after making them work, now the problem is with the ILK (thread here), but we continue with the project and I'm already preparing the order to "Motedis" to modify the cockpit of aluminum. We will continue informed, Greetings.
    Voy avanzando después de algún problema con los actuadores SCN5 (hilo aquí) y tras hacerlos funcionar, ahora el problema es con el ILK (hilo aquí), pero continuamos con el proyecto y ya estoy preparando el pedido a "Motedis"para modificar el cockpit de aluminio. Seguiremos informado, un saludo.
    • Optimistic Optimistic x 1
  5. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hello, today I have placed the order to Motedis of the aluminum to modify the cockpit, to see if the material arrives quickly and I put the equipment to work before the summer that is already close to me is over and it is already getting hot to play ... As soon as I get everything I put photos of the material and the assembly, what nerves and what desire ...
    Hola, hoy he hecho el pedido a Motedis del aluminio para modificar el cockpit, a ver si llega rápido el material y pongo a funcionar el equipo antes de que se me eche encima el verano que ya está cerca y ya empieza a hacer calor para jugar... En cuanto me llegue todo pongo fotos del material y del montaje, qué nervios y qué ganas...
  6. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    A couple of weeks ago I got the aluminum material from Motedis, but due to work issues I did not have time to get involved with the simulator. Today I have been doing the fastening system of the SCN5 actuators, I leave you some photos and we will continue updating as you go forward the modifications. The material used is slotted profile 20x40 type B.
    Hace un par de semanas que me llegó el material de aluminio de Motedis, pero por temas de trabajo no he tenido tiempo para liarme con el simulador. Hoy he estado haciendo el sistema de sujección de los actuadores SCN5, os dejo unas fotos y seguiremos actualizando conforme vaya adelantando las modificaciones. El material usado es perfil ranurado 20x40 tipo B.
  7. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Today I have been assembling the actuators in the cockpit and placing the base of the backet, we are modifying the whole structure to make it with movement and the truth is that it has made me sweat ....
    Hoy he estado montando los actuadores en el cockpit y colocando la base del bac ket, vamos modificando toda la estructura para hacerla con movimiento y la verdad es que me ha hecho sudar....
  8. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hi guys. After the summer break and a series of personal causes I have been disconnected for a while. I'll be back here again to keep reporting the new developments in my simulator. A greeting and I will update this post.
    Hola chicos. Tras el parón veraniego y por una serie de causas personales he estado un tiempo desconectado. Vuelvo otra vez por aquí para seguir informando de los nuevos avances en mi simulador. Un saludo e iré actualizando este post.
  9. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Well, I update the current state of the simulator with photos.
    Bueno, actualizo el estado actual del simulador con fotos.
    I have installed a tight connection box for the USB Devantech and the power supply. I still have to finish making the connections that I will make these days.
    In addition I have moved and reorganized the various power and electronic sources, as well as organized the whole mess of cables.
    I have removed the shifter from the G27 and instead I have made a Button Box with Arduino that I will explain another day with links.
    I have made an aluminum support for the power supply of the Thrustmaster steering wheel.
    I bought the Thrustmaster 599 Evo 30cms steering wheel and it is great and versatile.
    I have put a bicycle water drum holder to be able to leave a bottle of water for long periods of play.
    I have placed a hook to leave gloves and headphones.
    At the moment this is everything and little by little my project is taking shape.
    A greeting.
    He instalado una caja estanca de conexiones para el USB Devantech y la fuente de alimentación. Me falta por terminar de hacer las conexiones que haré estos días.
    Además he movido y reorganizado las fuentes de alimentación y electrónicas varias, así como organizado todo el lío de cables.
    He quitado el shifter del G27 y en su lugar me he fabricado una Button Box con Arduino que explicaré otro día con enlaces.
    He hecho un soporte de aluminio para la fuente de alimentación del volante Thrustmaster.
    He comprado el volante Thrustmaster 599 Evo de 30cms y que va de maravilla y que es muy versátil.
    He puesto un soporte de bidón de agua de bicicletas para poder dejar una botella de agua para los largos ratos de juego.
    He colocado un gancho para poder dejar los guantes y los auriculares.
    De momento esto es todo y poco a poco va cogiendo forma mi proyecto.
    Un saludo.
  10. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    We continue to modify and improve the cockpit. Now it touches a small detail: to place the electronic boxes add some stickers of danger due to electrical risk. I also moved the power supply of the Thrustmaster TS-PC steering wheel. I am also giving rigidity to the 2DOF system in the seat part ....
    Greetings.
    Seguimos modificando y mejorando el cockpit. Ahora toca un pequeño detalle: colocar a las cajas de electrónicas añadir unos adhesivos de peligro por riesgo eléctrico. Además he cambiado de sitio la fuente de alimentación del volante Thrustmaster TS-PC. Estoy también además dando rigidez al sistema 2DOF en la parte del asiento....
    Saludos.
  11. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    At the same time I'm also making a new Button Box illuminated, drilling, cutting, welding, ... In addition to the illuminated buttons, button with cover type airplane, I will also include a lit clock, because when playing with a projector with very little lighting, I lose the notion of time and I need to have the present time for the responsibilities that touch me, hehehe ... Later I will list the parts I have used.
    A la vez también estoy haciendo un nuevo Button Box iluminado, taladrando, cortando, soldando, ... Además de los botones iluminados, botón con tapa tipo avión, también voy a incluir un reloj iluminado, ya que al jugar con proyector con muy poca iluminación, pierdo la noción del tiempo y necesito tener la hora presente para las responsabilidades que me tocan, jejeje... Más adelante pasaré listado de las piezas que he utilizado.
  12. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Today I was finishing placing the reinforcements of the 2DOF part of the seat as it had enough slack or dead movements .... Now everything feels better and more direct, I had to make a new order to Motedis with more material.
    Hoy he estado terminando de colocar los refuerzos del 2DOF de la parte del asiento ya que tenía bastante holgura o movimientos muertos.... Ahora todo se siente mejor y más directo, he tenido que hacer un pedido nuevo a Motedis con más material.
  13. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hello, after finishing the illuminated Button Box, I put some pictures and I also attach the links to the materials I have used, except the box, which I bought at an electronics store in my town (measures 220mmx140mmx55mm). The truth is that I like how it looks in the dark, since in my case I play with a projector and it helps me to locate the situation of the switches. I would only need to buy some stickers with the name of the associated function. In my case I also take out a connector that I also use for a sequential shifter and for a future hand brake with a switch, so the Pro Micro board acts as a USB controller for these two accessories. I also feed the leds of the switches with a 12v power supply that I also use for the motors that do the vibration of the accelerator and brake pedals and that are controlled by Arduino plates.
    12mm Momentary Stainless Steel Metal Push Button
    16mm Momentary Stainless Steel Metal Push Button
    16mm Momentary Push Button
    Rotary encoder switch
    Potentiometer Knob
    Pro Micro ATmega32U4 5V 16MHz
    12v Car Clock
    Mean Well power supply LRS-75-12
    Male DC Power Plug Jack Connector
    GX16 Connector
    Connector Braided wire Micro-USB Cable
    220V-60W Adjustable Temperature Electric Solder
    Hola, después de terminar el Button Box iluminado, pongo unas fotos y además os adjunto los enlaces a los materiales que he utilizado, salvo la caja, que la compré en una tienda de electrónica de mi pueblo (medidas 220mmx140mmx55mm). La verdad es que me gusta cómo se ve en la oscuridad, ya que en mi caso juego con un proyector y me ayuda así a localizar la situación de los interruptores. Sólo me faltaría comprar unos adhesivos con el nombre de la función asociada. En mi caso además saco un conector que también uso para un shifter secuencial y para un futuro freno de mano con interruptor, así la placa Pro Micro hace de controladora USB para estos dos accesorios. También alimento los leds de los interruptores con una fuente de alimentación de 12v que uso también para los motores que hacen la vibración de los pedales de acelerador y freno y que son controlados por unas placas Arduino.
  14. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I like the Car Clock display detail.
    I have also seen people integrate TM1638 display board on the button box to show position or car temperatures.
  15. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Thank you. Yes there are more and better or more elaborate forms, but I needed for personal reasons and for having to play in the dark, to have an hour watch in view. It also shows me, at intervals, the ambient temperature (which suits me to regulate the temperature of the heating in the room) and also the supply voltage (so I have also controlled the power supply).
    Gracias. Sí que hay más y mejores formas o más elaboradas, pero yo necesitava por motivos personales y por tener que jugar a oscuras, tener a la vista un reloj horario. Además me muestra, a intervalos, la temperatura ambiente (que me va bien para regular la temperatura de la calefacción en la habitación) y también el voltaje de alimentación (por lo que tengo también controlada la fuente de alimentación).
  16. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Today in a while I have had to organize the installation and minimize the electronics that had mounted. I put the G27 pedals directly, with the Thrustmaster adapter, to the base of the TS-PC and the sequential Shifter goes directly to the new Button Box, so I have plenty of Arduino electronics and a USB hub. Now the area has been much cleaner and tidier, small details that visually improve the cockpit. A greeting and good weekend.
    Before / Antes
    After / Después
    Hoy en un rato que he tenido me he puesto a organizar la instalación y minimizar las electrónicas que tenía montadas. He puesto los pedales G27 directamente, con el adaptador de Thrustmaster, a la base del TS-PC y el Shifter secuencial va directamente al nuevo Button Box, por lo que me sobra la electrónica de arduino y un hub USB. Ahora ha quedado la zona mucho más limpia y ordenada, pequeños detalles que mejoran visualmente el cockpit. Un saludo y buen fin de semana.
  17. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    I update with a modification I had made but had not explained or taught. As the game room I share with my son and with a wardrobe of my wife's clothes, the simulator can not be fixed, since it depends on the situation I need to move it, and sometimes even take it out of the room. For this, and since it is very heavy, in the part of the pedals I have placed two aluminum brackets to place two rotating wheels that are always in contact with the ground. On the other hand, in the rear part, next to the seat, I raise the cockpit a little bit and introduce in its central part, left of the rear electronics, some wheels that also have a revolving base, with which I can move the simulator relatively easy and be able to maneuver with the. Also on one side back, I have placed a support where you can leave these wheels removable. (Wheels marked in red circle)
    In addition to that, looking for the storage room I found two tires of some support of a vehicle that I used to put on the back of the seat, in case in some case the seat supports were loosened, these tires cushioned a bit a possible blow both personal and break things of the simulator. (Rubber bands indicated in green circle)
    A greeting.
    Actualizo con una modificación que tenía realizada pero que no había explicado ni enseñado. Como la habitación de juegos la comparto con mi hijo y con un armario de ropa de mi mujer, el simulador no puede quedar fijo, ya que depende la situación necesito moverlo, y alguna vez incluso sacarlo de la habitación. Para ello, y dado que es muy muy pesado, en la parte de los pedales he colocado dos escuadras artesanales de aluminio para colocar dos ruedas giratorias que siempre están en contacto con el suelo. En cambio en la parte trasera, junto al asiento, levanto un poquito el cockpit e introducto en su parte central, debado de la electrónica trasera, unas ruedas que también tienen una base giratoria, con lo que puedo mover relativamente fácil el simulador y poder maniobrar con él. Además en un lado atrás, he colocado un soporte donde poder dejar estas ruedas desmontables. (Ruedas señaladas en círculo rojo)
    Además de eso, buscando por el trastero me encontré con dos gomas de algún soporte de un vehículo que he utilizado para poner en la parte trasera del asiento, por si en algún caso se soltaran los soportes asiento, estas gomas amortiguaran un poco un posible golpe tanto personal como romper cosas del simulador. (Gomas señaladas en círculo verde)
    Un saludo.
  18. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Since this last period was giving to Dirt Rally and these last days to the new Dirt Rally 2.0, I had no choice but to put my hands to work and make a handbrake, because pressing a button ruined me a bit experience and I lost time or do wrong the forks ... Some time ago I already acquired a hand brake on Aliexpress, but the lack of time made me save it, but in the end I decided to look for ideas and material in the storage room to be able to adapt it to my needs, but most importantly, adapt it to my cockpit without having to disassemble the sequential shifte or manual, had to live with both. The best thing would have been to do it with a load cell, but the truth is that the button box I have already left an outlet to connect a micro switch, and this was the simplest thing. And that's how it ended up, as the photos show, I modified the original and I used kneecaps and a spring that I had there, I changed the foam that was made of a grip by a foam bike handle also, I have placed a micro switch and it is already working like a charm, living in perfect harmony with the rest of peripherals, jejeje, ... and the truth is that playing the sensation when taking hairpins has improved a 1000x1000. I hope you like it.
    A greeting.
    Link Hand Brake Aliexpress
    Dado que este último periodo le estaba dando a Dirt Rally y estos últimos días al nuevo Dirt Rally 2.0, no me quedó más remedio que ponerme las manos a la obra y hacerme un freno de mano, ya que pulsar un botón me arruinaba un poco la experiencia y me hacía perder tiempo o hacer mal las horquillas... Hace tiempo que ya adquirí un freno de mano en Aliexpress, pero la falta de tiempo me hizo guardarlo, pero al final decidí buscar ideas y material en el trastero para poder adaptarlo a mis necesidades, aunque lo más importante, adaptarlo a mi cockpit sin tener que desmontar el shifte secuencial ni el manual, tenía que convivir con ambos. Lo mejor hubiera sido hacerlo con célula de carga, pero la verdad es que del button box que tengo ya dejé una salida para poder conectar un micro switch, y esto era lo más sencillo. Y así es como al final ha quedado, tal y como muestran las fotos, he modificado el original y he utilizado rótulas y un muelle que tenía por ahí, he cambiado la espuma que hacía de empuñadura por un puño de bicicleta de espuma también, he colocado un micro switch y ya está, funcionando a las mil maravillas, conviviendo en perfecta armonía con el resto de periféricos, jejeje, ... y la verdad es que jugando la sensación al tomar horquillas ha mejorado un 1000x1000. Espero que os guste.
    Un saludo.
    Link Freno de Mano Aliexpress
  19. jnikitas
    jnikitas New Member
    45Coins
    Buenas, ya he desmontado mi 2dof con motores de limpiaparabrisas que para mi tamaño son lentos, (1.86, 85kg) y estoy con ganas de arrancar uno nuevo con actuadores lineales, aprovecho que hablamos los dos español, para preguntarte respecto a las especificaciones de torque, velocidad y recorrido de los motores, y si te parece que esta bien el tamaño que estas usando o mejorarias algo, respecto a estos tres parametros. Yo tengo que comprar y dado su costo, no quiero comprarlos en vano.
    Gracias de antemano,
    Un abrazo desde Argentina!
    Saludos,
    Jorge
    153,770Coins
    +11,149 / 57 / -2
    Please be aware that you can dual language post, like @cover4x4 did, but it is part of the Forum Rules that you also include English, doing so via Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
