Showroom 4Dof upgradeable to 6Dof
Discussion in 'DIY Motion Simulator Projects' started by mariano68, Aug 9, 2017.
  1. Gadget999
    12,035Coins
    What did the ballscrews cost each ?
  2. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    They are Chinese, I got them a year or more ago, I don't remember but sure the same as the rest of the guys that got them there.
    152,367Coins
    +11,076 / 56 / -2
  4. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Returning to the project...
    I had to put it on stand by because of the lack of space to put the simulator, as it has a footprint of about 170x110cm, So, I built a little external room for it in a lateral corridor of my home, it took two days with some help...
    Not the neatest but big enough to put the computer and sim inside and have all the privacy I want, cause it is outside the house :). I used all recycled materials from other jobs. It is 240x170cm. I got my " Man's cave" and I can keep building my new 4dof sim.
    • Like Like x 5
  5. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Finally got my first 3d printer!
    Ender 3:
    Time to learn fusion 360...
  6. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    V2 of my linear actuator is coming...
    First part printed with a 0.8 nozzle, (ball nut support) perfect fit!
    20181015_215647_HDR.jpg 20181015_220009_HDR.jpg 20181015_222133_HDR.jpg 20181015_222211_HDR.jpg
    Upper part ready too...
  7. Gadget999
    12,035Coins
    Can we see a video of the actuators working
    What power and rpm are the winch motors ?
  8. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    As you can read, it is still a work in progress...
    Also two diff motors for testing, big 1hp winch and a smaller but already with encoder mounted servos.
  9. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Prototype actuator base, ready
  10. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I will put this here too...
    Got an old friend to jump up into my project, he is doing the electronics now, already got the encoder (2000cpi) to work with arduino, but arduino and also the sabertooth will get out of the ecuation soon... I want my little 48v servo motor to work at that 48v!
    For now:
    Just quoting my friend Hernan:
    In more technical terms, the pic receives the quadrature signal from the enconder, and generates a pwm proportional to the position, that is filtered and sent to the arduino as a 0 to 5V signal, as if it were a pot.
    inside the pic you can count all the laps that are needed, so that the 0 to 5 V end up representing the number of laps multiplied by the resolution of the encoder, in our case it would be something like 70,000 positions.
    But, in the arduino all that goes to the bin, it must have 10bit input, 1024 positions. So that is worse than reading my tester hahaha.
    BTW, that red part, its the bottom of my new actuator design.
  11. thefost
    thefost Member
    242Coins
    Any chance you were able to make progress on the build? I'm planning on making something similar.
    152,367Coins
    +11,076 / 56 / -2
    Amazon is a convenient option.
  13. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Hi guys, coming back... hug:
  14. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I can't see the pic o_O
    152,367Coins
    +11,076 / 56 / -2
  16. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
  17. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I'm looking for a 48 or 60V motor driver, any clues?
    Thanks anyway!
