Showroom 2 DOF SIM TRY #2
Discussion in 'DIY Motion Simulator Projects' started by MuñozChile2dof, Jan 5, 2018.
  1. MuñozChile2dof
    MuñozChile2dof 2 DOF SIMULATOR ARDUINO AND IBT-2
    Hydraulic technician
    CHILE
    54Coins
    First test sorry for the bad quality
    152,367Coins
    +11,076 / 56 / -2
    Great to see your rig is moving, that is always a sense of both accomplishment and relief :thumbs
    It does seem like your sway axis is reversed, it should lean away from a corner.
  3. MuñozChile2dof
    CHILE
    54Coins
    thank you @noorbeast i have to test all in the new plataform and make all the corrections
  4. MuñozChile2dof
    CHILE
    54Coins
    some good news
    i test my sim prototype and works ok
    now i plain to do my final sim with an aluminium structure
    special thanks to @noorbeast for help me to correct my faults
    152,367Coins
    +11,076 / 56 / -2
    Great you got your prototype sorted, unfortunately your video is unavailable and I suspect may be marked as private instead of public on YoutTube.
  6. MuñozChile2dof
    CHILE
    54Coins
    sorry i change the video to public
    152,367Coins
    +11,076 / 56 / -2
    The video works now :thumbs
  8. MuñozChile2dof
    CHILE
    54Coins
    After a good time i decide to comeback with my project of a 2dof sim, with a frame in aluminium 2 worm gear motors 25:1, arduino uno, two moto monster shields, two power supplies one for each moto monster and two 10k and 10 turns potentiometers, but the sistem fails, when i sit in the chair the motor over turn and dont come back, this fail happens no matter the configuration, in smc3 or simtools, can this be a fail by design or can be the pots for be of 10 turns?
  9. MuñozChile2dof
    CHILE
    54Coins
    Photos of smc3 and simtools
  10. MuñozChile2dof
    CHILE
    54Coins
    this is a video of the fail.
    152,367Coins
    +11,076 / 56 / -2
    I suspect you need 40mm Center To Center or less on the levers, particularly with 25:1s, as with a compact design you need to maximise torque, not speed.
    The video is not working for me, have you made it public?
  12. MuñozChile2dof
    CHILE
    54Coins
    now is public, sorry
  13. noorbeast
    152,367Coins
    +11,076 / 56 / -2
    Also 40 degrees for levers up and down is about the max range for the effective use of torque, over that and effectiveness drops off rapidly and just strains the motors.
    Refining your PID settings may help as well, but sort the design issues out first.
  14. MuñozChile2dof
    CHILE
    54Coins
    ok noorbeast i make the changes the fast i can, i hope this project works fine soon, thank you so much.
  15. 427Cobra
    427Cobra There is no substitute for cubic inches
    Sweden
    567Coins
    Nice build! I like your compact design. Looking forward to some videos when the fine tuning is done.
  16. MuñozChile2dof
    CHILE
    54Coins
    After a long time, my 2dof sim comes to life :)
    I use the SMC3 Arduino 3DOF Motor Driver and Windows Utilities, thanks @RufusDufus. And thanks @noorbeast for your constant help.
    I use two Ibt-2 H bridges and an arduino uno.
    My rig is made with 30x30 aluminium profiles.
