value1
Falcon 4 BMS Plugin 2.0.0.1
SimTools game plugin for Falcon 4 BMS
  1. value1
    14,239Coins
    Falcon 4 BMS Plugin - SimTools game plugin for Falcon 4 BMS
  2. Historiker
    9,205Coins
    You are a GOD (pause for lighting bolt.....no? Good). Thank you for this, I had forgotten to request it. BMS is one of my other winter time flight sims.
  3. Historiker
    9,205Coins
    Since I was testing out DCS with my 6DoF miniature platform I thought I would fire up Falcon4 as well.
    What I found:
    1. Oddly there was not movement until I set the min max manually. Even doing a capture didnt help for some reason. All settings during capture stayed around 32,000 :eek: I set them down to around 20/-20 and got movement. The Game Data Input section did show values changing, etc.
    2. Roll, Pitch and Heave work perfectly.
    3. Again, like DCS, yaw seems to be slaved to the compass and does nothing other than stay all the way to the left (if heading west or north) and all the way to the right (if heading east or south).
    The Falcon4 plugin does not have surge nor sway so I could not evaluate those inputs.
    Otherwise, well done and again I thank you Value1!
  4. value1
    14,239Coins
    I'll take care of this.
  5. fledge2b
    fledge2b New Member Gold Contributor
    Nagoya
    603Coins
    3DOF, SCN5
    Can I use this plugin for Falcon4.0 (original falcon) ??
  6. value1
    14,239Coins
    Hmm, I can't remember and don't have Falcon installed right now. Can you test this and report back, please.
  7. dance77
    dance77 New Member
    286Coins
    2DOF, SCN6
    I want falcon bms 4.33 plugin
  8. Historiker
    9,205Coins
    I have not tested it with BMS 4.33 yet (still have to rebuild my flight sim rig) but it was working with BMS 4.30 (beta). It should work with 4.33
  9. Reinaldo
    Reinaldo New Member
    Brazil
    9Coins
    Hello Guys,
    I tested this plugin in Simtools V2.0, V2.1, v2.2.5 and in none of them the Plugin is listed in the "Game Selection" of the "Game Manager". I installed the plugin normally through the "UpDate Plugin".
    Has anyone had this problem or know how to solve it?
    Thank you.
  10. yobuddy
    51,532Coins
    @Reinaldo ,
    This is the normal operation of SimTools until a license has been detected.
    Otherwise it runs in Demo mode with only Live for Speed available for play.
    Are you maybe in Demo mode?
  11. Reinaldo
    Reinaldo New Member
    Brazil
    9Coins
    You hit the nail on the head yobuddy,
    I switched to a computer and forgot about this important detail.
    I'm sorry for my carelessness.
    Thank you.
  12. yobuddy
    51,532Coins
    No worries buddy, take care!
  13. Icebeat
    Icebeat New Member
    - 61Coins
    Hi there,
    Any possibility to implement Sway, Heave, Surge forces similar to the DCS plugin? also could it be possible to have on-ground info?
    Thank you for your work.
  14. javiluco
    javiluco New Member
    24Coins
    I just tried to install this plugin and it doesn’t work.
    any suggestions?
    153,824Coins
    +11,151 / 57 / -2
    What version of SimTiools are you using and is it licensed?
  16. javiluco
    javiluco New Member
    24Coins
    V3 minimal license, not demo but don’t remember exactly
    that’s a lot
    153,824Coins
    +11,151 / 57 / -2
    SimTools v2 plugins are not compatible with v3.
    You can install v2 on the same computer as v3 and use the same license.
    This is the v3 Plugin library: https://simtools.us/plugin_library/
  18. javiluco
    javiluco New Member
    24Coins
    Thanks a lot for your response.
    Could you please send me the axis assignment? I imported the plugin in the v2 but there aren’t any assignments on the configuration and no movement are flighting in BMS
    BR
    153,824Coins
    +11,151 / 57 / -2
