SimTxus Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by el_txus, Mar 4, 2009.
  1. el_txus
    el_txus Member
    Las Palmas de Gran Canaria - España
    421Coins
    Hi Ego
    ok thanks I will try this weekend, but I do not understand why?
    Thanks again Best Regards
  2. el_txus
    el_txus Member
    421Coins
    HI
    This weekend I have continued adjusting the G effect with the Rfactor. I think I have improved it a little bit, but I still have to improve the response of the Simulator. Ego, how do you see the movements of the simulator? What should I improve in your oppinion.
    http://www.youtube.com/watch?v=bnw8njsYS2A
    Rfactor Profile for Force Profiler 1
    Txus Rfactor4.rnr
    Best Regads
  3. pointer4
    pointer4 Member
    Hungary
    276Coins
    I don't have time for anything, moreover a friend of mine proposed to how we shall build a simulator for him ...
    I turn off my cellphone for today, and I dealt with the thing.
    http://www.youtube.com/watch?v=qG4T9Nr6tgg
  4. el_txus
    el_txus Member
    421Coins
    Hi
    More profile test, now with Race 07. I need more fine adjust but I think I've improved a little
    http://www.youtube.com/watch?v=nw53mIPX2C0
    Best Regards
  5. dagra
    dagra New Member
    0Coins
    I think your sytem looks great.
    What is the clicking noise in your video?
    The last video you added is not veiwable says you have to be your friend to see.
  6. el_txus
    el_txus Member
    421Coins
    Hi
    Thanks, the click is for the relays and the electrovalves. I do not have much space to put the camera, I hope to find a better place.
    Best Regards
  7. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    youtube is ok, but you have to remove the restriction for private use in the video settings. Currently we are not allowed to see your video.
    regards
  8. el_txus
    el_txus Member
    421Coins
    Hi
    I´m sorry, the video is public now
    Best Regards
  9. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    370Coins
    your Sim definitely looks very great and massively !!!
    I'm wondering if a profile of a Sim like this one could ever be balanced and made THAT perfect for race simulations like a frex or frex-like system... I always thought, that a RNR-like or Joyrider-like simulator would be perfect for flight sims or mean rollercoaster rides ;) ! But the most important thing is, that you are happy with your machine and that you'll have a lot of fun with it :yes: !!!
    To avoid those clicking sounds in the video a litte bit, you could try the same way as I did:
    Connect the microphone part of a headset to your DV cam and place the headset-mic next to the speakers.
    Then you do not hear the clicking sounds so much anymore AND your cam can stay in its place. I did the same on my video, because I had too much noise due to the SCN5 movements at the beginning...
    Best regards,
    Chris
  10. el_txus
    el_txus Member
    421Coins
    HI Schnullerbacke
    Thanks for your feedback, my sim is actually a little big because I wanted to be able to move the screen along with the pilot, it is clear that there will never be an answer as a system driven by SNC5, but my target was transform the original R'n'r just in that and I think the target is accomplished. I even improved a bit or install the CG system 3 monitors to compensate for the weight away, but that I needed to play and has been a very long one.
    I can connect a microphone. I don´t use a DV cam my camera is a Photo cam in video mode.
    Best Regards
  11. pointer4
    pointer4 Member
    Hungary
    276Coins
    I have a same problem :) I changed my tv to a FullHD, what is heavier, and moreover
    i lost some of my weight 8)
    This will be the next upgrade: :clap:
  12. el_txus
    el_txus Member
    421Coins
    Hi Pointer4
    is a good solution to adjust the CG if other drivers use the sim with a different weight.
    Best Regards
  13. el_txus
    el_txus Member
    421Coins
    Hi
    I´m working in a little gauge system for my simulator I using a 7 Samsung Usb Monitor and Force-Profiler gauge. actualy y have a little problem with the values generated by the profiler but, I need more time for working on it.
    Best Regards
  14. el_txus
    el_txus Member
    421Coins
    Hi
    Now does the gauge, I forgot to copy the driver with the new 2.1 version of the profiler
    a short video
    http://www.youtube.com/watch?v=DNZ_bkhb6v8
    Best Regards
  15. pointer4
    pointer4 Member
    Hungary
    276Coins
    I have a feeling like that, as if we would be neighbours :rofl:
    Me, too looking the touch-buddy now :happy:
  16. el_txus
    el_txus Member
    421Coins
    Hi Pointer4
    Really a very good job, it's amazing how our jobs are like, Could this industrial espionage?, Also using these plates read Bodnar. I am about to add a few buttons on my steering wheel more. I hope to do a job as good as yours.
    Best Regards
  17. el_txus
    el_txus Member
    421Coins
    Hi
    One video more, the gauge in action. I need create a new lap time counter but now all it's work
    http://www.youtube.com/watch?v=mIstQCNtQDo
    Best Regards
  18. el_txus
    el_txus Member
    421Coins
    Hi Again
    The Simbin Profile for X-sim 2.1 software.
    http://www.youtube.com/watch?v=YQIktziY6M8
    Best Regards
  19. egoexpress
    422Coins
    WE are not able to watch your videos, as you have selected private use in the youtube video settings once again.
    Please change them to public use
    regards
  20. el_txus
    el_txus Member
    421Coins
    Hi
    sorry I do not know why it have that option by default?
    thanks for warning me again
    Best Regards
